Wireless Connection Have a new Advent 5431 Laptop on Vista that I cannot connect to a wireless network in my home. Other laptops working no probs any ideas??
  • martinjcochr Dec 28, 2008
    Other PCs are all on Vista and the new laptop is picking up the router but not connecting to the internet
  • Eric Ramirez
    Eric Ramirez May 11, 2010
    Are you not connecting to the wireless router or not connecting to the networked PCs?
    If the existing network consists of Windows XP machines, they must be upgraded with Link Layer Topography Discovery (LLTD) before they can interface with the new scheme of networking used by Vista. LLTD is available as a download from Microsoft and it installs easily to an XP machine with SP2, but there is a glitch in the installer when you have already upgraded to SP3. It can still be done, just has to be installed manually.
    Please re-post more specifically what you are trying to connect.
    Novelist:
  • 101 Answers
You might have an anti-virus or firewall program installed on this laptop that is blocking your access. Norton Internet Security and TrendMicro PC-cillin are notorious for creating connectivity problems if they are not properly configured.
Posted on Dec 28, 2008
  • 142 Answers
Some older routers are not compatible with windows Vista. Make sure yours is, and that the ports on your router are configured to allow internet to work with windows vista.
  • Michael Lake
    Michael Lake Dec 28, 2008
    hmm, im not exactly sure at this point, i would try callin either the laptop's company, or thje router's company. they will fix the problem for sure.
We have an Advent 7088 laptop and want to connect it to wireless router. We thought a wireless facility was already installed in the 7088 but when we try the wireless on/off button nothing happens. What...
Try this: I found it after doing some searching on the web.
Wireless card stops working after upgrading to Windows Vista
After upgrading to Windows Vista everything works fine apart the Marvell Wireless card, when you press the button nothing happens.
There seems to be three different ways of solving this problem (there is a fourth - don't install Vista) and I've listed them below, hopefully at least one should work for you.
The first solution is to press the wireless button while Windows Vista is loading, you have to be quick though as it only works if you press the button between the loading scrolling lines logo (after the post screen) and before the windows logo appears.
The second is to go into Device Manager, select the Marvell Wireless card and then go to Properties>Advanced>Default Adhoc Mode. Here change the Default Adhoc mode to B or G. When you confirm the change the wireless connection should become active, if it doesn't then press the wireless button and try changing the setting again.
The third method is to create a desktop shortcut to the wireless adapter. Go to [Network and Sharing Centre]>[Manage Network Connections] and then right click the wirless connection and choose Create Shortcut. You can then switch on the wireless at any time, just point at the shortcut then right click and chose Disable. Once its disabled right click on the shortcut again and choose Enable. It should then connect within 20-30 seconds.
Support site: http://www.uktsupport.co.uk/advent/laptop/7088.htm
Mar 11, 2010 | Computers & Internet
Hi, till recently I was conneted to the internet (AOL) via cable connected to a NetgearDG834G v3 Modem router with no problems. Replaced PC with laptop (vista home premium) and connected via cable in the...
do your router modem got a wifi wire? or does it capable on wireless connection. try to use a windows xp not vista. it must be the problem. or configure it manually on your wireless connection in control panel. hope that helps!
CHARCOIS
Aug 09, 2008 | Computers & Internet
Comp will not connect to internet and tells us there is a cable not connected. It is wireless and the modem is working with all other comps in house. I have checked the modem, switched it off and...
have you installewd the drivers for the modem ? if you have go to desktop and click settings got to network settings open this up it should show any connected networks if not click new connection then go throught the proceedure you can try the first internet connection if not try the advanced option for the wireless.. make sure you installed the wireless drivers as well a it wont work without these.. Good Luck A
Jun 30, 2009 | Advent Netbook
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Trying to take a new wireless built in laptop, home to my current wireless network. The new laptop recognizes my home wireless network, but unable to connect to it. The laptop is a Dell studio 17 and...
If you are hardly doesn't connect even your wireless station is been detected why not try to set your settings manually in your wireless card.
This is when you are behind a router.
Goto Network and sharing center. Click on Manage Wireless Network. Click on Adapter properties. Click Internet Protocol version 4. Click properties, then set the ipaddress of your laptop it doesn't have to be identical to any of your existing connection, your subnet, default gateway. And also input your IP DNS.
May 18, 2009 | Computers & Internet
Cant connect wireless internet connection
pls configure first WAN setting WI FI AREA NETWORK,IP address connection from the router wi fi,subnet, and protocol.
May 10, 2009 | Recoton Advent Advent Q2035A 20" TV
Wireless connection switch on
The combination key should be fn and f10 although our new laptop can not find any networks wirelessly even with this turned on so help on this would be appreciated
Apr 23, 2009 | Computers & Internet
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
