Question about Toshiba Portege 4010 Notebook
Boot safe mode
No i have not tried to boot up with safe mode. I don't know how to do that. and it does not give me any options other then to press ctrl-alt-delete. and then i continuously do that getting no where.
  • 59 Answers
To boot safe mode,
1. tap the f8 button while your computer boots...before your windows starts load and just after you press the power button.
2. a screen will appear it will give you the option to boot in safe mode, select it
Posted on Dec 29, 2008
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How to put samsung n120 into safe mode
Hello Yara Lima,
First press power on switch, then press F8 key now your are showing option .
droup down arrow key and select windows start from safe mode. then press enter now windows is booting in safe mode. pls try...
thanks
Mar 05, 2014 | Samsung N120-12GBK Netbook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I cant' get out of safe mode. I press f8 and tell it to start windows normally but it goes to safe mode automatically
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 11, 2010 | ASUS 90-A4C1K1000 Keyboard
How do i turn off safe mode
Most computers when you boot it up give the option of "Boot Menu" upon the first few seconds of powering the machine on. Look at the screen and see if it reads Press F1 or F2 for Boot Menu. From there you can toggle off the safe mode option. Sometimes it's the delete key or alt key for some other computer providers as well.
Hope this helps,
Marty
Nov 27, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Forgot my toshiba laptop login password ? can u suggest how to login now ?
It is not a big deal. You can try the safe boot option
restart the Laptop in safe mode by pressing the F8 key while rebooting
Select safe mode on Advance boot option
Log in as administrator
Go to control panel and Delete the previous User and create another user with same name
Restart the computer in normal mode
If this Works please say thanks and If this does not work let me know, I'll give you other options
Oct 05, 2009 | Toshiba Satellite L305-S5921 Notebook
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
Want to Do a Restore
Try starting your computer in safe mode and do a virus scan once in safe mode. While in safe mode Windows only loads the basic devices to run your computer and usually viruses are not loaded untill windows starts in regular mode. Don't panic once you are in safe mode and your screen looks all grainy, this is normal.
  1. Restart your computer and press F8 as soon as you turn it on.
  2. Click the "safe mode with networking" option
  3. Update your antivirus
  4. Do a full system scan
  5. Restart your computer and hope for the best.
If that doesn't work, than reinstall windows.
If you need further assistance, let me know.
Jan 05, 2009 | Acer Aspire 3680 Laptop
Toshiba Portege 4010 Notebook Logo
194 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
