Question about Memory Upgrades 1 GB USB 2.0 Micro Flash/PowerUser Drive 1 GB 1 x USB Portable (MY14576FT) Drive
Can't store anything lately
Trying to add a resume on my memorex traveldrive and it keep showing an error message or hour glass which eventually tell this program is not responding and other verious saving problems please help
  • 3 Answers
Hi, did you format the flash drive? If you are using windows, right click on the drive and select "Format...". You can repeat the operation a few times. If it's working, try to add your resume again. How old is the drive? Good luck!
Posted on Jun 20, 2007
SOURCE:
I have Memorex Ultra Traveldrive - 160GB USB Hard Drive. I dropped it by accident and now I can't get information stored in it. Please help!!
Gently tap the hard drive with an opened hand and see if you can get it to spin up one last time.
click start control panel administrative tools computer management disk management if you can see your drive right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Some addition links found on Google
http://www.datarecoveryreview.net/
Of course it can be sent to a data recovey company if you really have to get the data off.
hope this helps
Oct 12, 2012 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have deleted what was in the usb traveldrive and it still shows that it is full capacity. How do I find what else I need to delete? It doesn't show me anything is in it but it's telling me there is.
Hi!
To see all the contents of the drive, go to Control Panel, switch to classic view and open Folder Options, then go to View and in the list, choose "Show hidden files and folders"
Hope this helps!
Jan 03, 2011 | Memorex Mega TravelDrive 4 GB USB Hard...
Need software for 512mb traveldrive using Windows 7
The TravelDrive is a "plug-and-play" device, and Windows 7 supports Plug-and-Play.
So, any device-drivers are included, and will automatically be used when you connect the TravelDrive.
What problems are you having? Symptoms? Error-messages? Does the TravelDrive work in some other computer? Does any other USB device work in the USB port that you are using for the TravelDrive?
Dec 18, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
How to use
you can download your memorex mega travelDrive 4 manual from this link
http://www.memorex.com/PageFiles/1180/manual.PDF
and learn well how to use hope that was helpfull
Sep 11, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
When I plug in the travel drive, it does not show
The only way to recover the data will be to try a company that specifically deals with Drive Data Recovery. This will not be cheap, so you will have to decide on the value of the data you are trying to retrieve
Mar 06, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Detected With Error Code 10 in Device Manager in Windows XP
Have you tried also plugging in the DC usb cable into the traveldrive? I was having problems where my computer wasn't working properly with my drive unless I had it either plugged into a powered usb drive/hub or I had the DC plug in as well.
Jun 04, 2008 | Memorex Ultra Traveldrive - 80GB 80 GB...
Computers & Internet Logo
64 people viewed this question
Top Memory Upgrades Computers & Internet Experts
Alun Cox
k24674
Are you a Memory Upgrades Computer and Internet Expert? Answer questions, earn points and help others
