Question about GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side not making ice
Ice in icemaker just not dispensing
The proble is most likely in the wiring connector that is located under the plastic cover on the top hinge,remove the one screw holding it on and remove the cover to get to the connector.I had to ben the male end of the wire connectors slightly to get a good connection
and plug it back in.
Posted on Dec 31, 2008
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Aug 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
47 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
