Question about Bosch Dishwashers
No water coming into dishwasher
Bosch dishwasher is 4 years old. When started a huming sounds begin and no water comes into dishwasher....
    President:
  • 2,692 Answers
The hum is a selinoid. The water inlet valve is selinoided operated so I woudl sspeculate that either the valve is bad or the selinoid is. You can check the selinoind with an ohm meter. Since it hums I am guessng that the valve is bad. Likely they come together as one unit.
Posted on Dec 28, 2008
I currently own a BOSCH Dishwasher approx 2.5 years old. It just runs for 3 minutes then stops and starts again - red LED light by Tap icon flashing
Hi, that sounds like you have a fault in the water inlet valve. Best get checked or replace the water inlet valve.
Mar 27, 2016 | Bosch Dishwashers
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Jul 26, 2009 | Bosch Dishwashers
Bosch dishwasher not working
Sounds like the water pump has failed.
May 29, 2009 | Bosch Dishwashers
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwasher was leaking; now gets "stuck" 3 minutes after starting
You're describing a number of issues related to old age and maintenance. First, you've likely got a mechanical timer that is getting stuck. If the price of replacement is outside your budget for an old warhorse....
Second, in come cases, the timer takes care of water level...in most, however, there is a float or aeneroid level sensor. If it is a float...it may be clogged/jammed with detergent or debris. Located in the wash tub near the front. Clean it up. If it is an aeneroid, it has a tube going from the tub to the lower part which hooks into a 3 inch or so flat sided round item with two wires coming out. With the power off, test it by blowing and sucking on the tube. Blowing into it should open the switched leads ...sucking should hold a 'vacuum'. The pressure of water opens and closes this switch to determine water level.
Jul 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Jun 30, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
Dec 28, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
265 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
