WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
HP Director Software
Where could I download the HP Director Software I had H P Director installed, has been deleated any how, now required the same one or advanced H P Director for my HP PSC 1410 All in one inkjet.
  • Anonymous Apr 21, 2009
    I can not find HP Director on my computer. I need to install HP 4200 series 4215 office jet.
I purchased a new HP Officejet 5740 printer. It worked fine for a while but now will not print at all. What do I need to do.
I'm guessing you don't think it's a hardware fault? (The machine physically broken; as that would warrant a refund, repair, bin)
So if there's nothing wrong with the printer physically, then it's probably a 'driver' (I have no idea of your IT knowledge). HP are very sneaky, in that they make you install all kinds of software you really don't need, and they make it very difficult to uninstall it sometimes.
Firstly check all your cables/wireless settings. Try plugging the printer into a different USB socket. Try printer.
Download the latest drivers for your printer from the HP site.
Uninstall every HP application that relates to your printer.
Then preform the following;
Step one: Clear temp directory
1. Type %temp% in the run or search for programs and files field
2. Highlight all the files in this folder, and then press the delete key to delete. If you get a message that the file is in use you will need to skip this file(s).
Uninstall the software using the scrubber program:
1. Download the full feature software and drivers
http://support.hp.com/us-en/drivers/selfservice/hp-officejet-5740-e-all-in-one-printer-series/6617253/model/6617254
2. Once the download is finished double click on the file to extract the software.
3. When the installation window opens press the cancel button to stop the installation
4. Type %temp% in the run field
5. Look for, and open the folder starting with 7z (Example: 7zS2356)
6. Right click on the folder, and select Copy
7. Close that window, and all your open windows, and then in the middle of the desktop right click your mouse, and select Paste. This will move the 7z folder to your desktop.
8. Open the 7z folder you just copied to your desktop
9. Open folder Util
10. Open folder CCC
11. Run the L4uninstall.exe
12. When the uninstall has completed restart the computer
Once restarted use the same installation file to reinstall the software and drivers. Restart again, and hopefully you haven't wasted your time
Oct 26, 2015 | HP Officejet 5740 e AiO Printer
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Set up printer wireless with out cd
1 Go to hp website HP Drivers Downloads
2 search model of printer
3 download software and driver
4 Install onto your computer
5 go to printer and connect to wifi
Feb 13, 2014 | HP Computers & Internet
I have hp photosmartc3100 all in one series and have lost my windows cd and would like help to download it thank you
You can install this printer by downloading the printer software from this link and use that driver to install your printer to your computer.
Just click HERE and select your operating system of your computer and proceed with the driver download and once done downloading you can run the software to install the printer.
Oct 27, 2010 | Computers & Internet
I've lost the software install CD-Rom for my HP Desktop F2100 All-in-one series. Can I download the software from the internet?
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3235678&lc=en&cc=us&dlc=en&lang=en&cc=us
This link must help you. There were number of other models I found on the same page.
Here's the page where you actually get to choose the model.
http://h10061.www1.hp.com/ccsearch/search?pname=F2100+all+in+one&qry=software&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=&search=0&submit.x=0&submit.y=0
Once you click on the model you will have an option called Softwares and Downloads. This can help you download the software for the version of windows you are running in the system.
Regards,
Sai
Nov 08, 2009 | HP Computers & Internet
How to instal my hp psc 1317 without a cd
go to http://www.hp.com/#Support enter your product name/number (psc 1317) then your operating system and it will give you available downloads for drivers and software
Sep 16, 2009 | Computers & Internet
How can i instal my hp laserjet 1005 series on a dell inspiron 1300 i lost my software
You can download the driver using the link below.
Start driver software setup with printer USB cable not connected:
HP LaserJet 1005 Printer - Download drivers and software
Sep 10, 2009 | Dell Computers & Internet
I need a driver for hp deskjet d2460
You can download the software here:
deskjet-d2460-printer-driver/">http://www.soft82.com/get/download/windows/hp-deskjet-d2460-printer-driver/
Once on the page your download should start immediately :-)
That will get you back printing
Oct 02, 2008 | Computers & Internet
Computers & Internet Logo
682 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
