Question about Panasonic Lumix DMC-FZ20 Digital Camera
Lens scrunched A friends camera dropped on the lens and the center lens tube is now crooked in its holder. Can I just open the lens assembly and get the center tube back on track? What do i do to get it apart 'easily'? Thanks
    Problem Solver:
  • 40 Answers
Yea, I'm guessing this is not a do it yourself'r kinda project. As for taking camera stuff apart it requires tiny screw drivers. Sometimes small pointy pen/pocket knife blades work. But you're more than likely going to strip the heads out. Over the eons, I have taken some cameras apart, but confess that I've never put them back together again.
Posted on Apr 29, 2007
Crooked camera lens
Camera got dropped, lens got pushed in on one side? If you can straighten it yourself by pulling it out straight on that side, it might work perfectly afterwards.
Feb 11, 2012 | Canon PowerShot A95 Digital Camera
Compact digital camera lens assembly jammed after dropping
i worked as service engineer on life support equipment for 15 years but alas my cannon g10 with above symptoms didnt make it back together .... never start without a manual to assit you ....adrian
Dec 27, 2009 | Casio Exilim EX-S500 Digital Camera
Shutter stuck open after a tree limb struck it
Hello. Sadly this is a very common usually fatal problem.With little to loose try firmly smacking the bottom corner of the camera below the lens in the palm of your hand while powering up. Don't hit the lens itself. Also Dropping it on its back from 2 or 3 feet onto thick carpet while powering up may work. Lens replacement often costs nearly as much as a new camera these days.
Dec 10, 2009 | Computers & Internet
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Dropped camera
Lens won't come out and lens cover won't open. New battery what do you do to make it work?
Jun 25, 2008 | Kodak EasyShare CX7430 Digital Camera
Dropped camera. lens open and crooked
Sorry to say you have broken the lens, replacement of the lens is the only practical repair and if you cant swap one yourself from a dead camera it would be beyond economical repair.
If you are adventurous you could buy a faulty one of ebay and swap the lens or if the faulty one has a broken screen or mode dial swap yours over to the faulty one..
there are a couple of "tricks" do getting this camera open drop me a line if you decide to proceed...
best of luck
Apr 11, 2008 | Kodak EasyShare DX6490 Digital Camera
Casio camera lens stuck
hi
this is repairable u ask ur near servicecenter
Feb 18, 2008 | Casio Exilim EX-S500 Digital Camera
Dropped dsc 650
sir, internal lens unit dislocated or broken ,its randomly shuts off u try any local reparer
Jan 31, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
My inner lens cannot open
Hello DJ Upi, This is a lens assembly mechanism problem. It is a delicate part of any camera. The lens assembly is composed of several servomotors, coils, some sensors and the actual lens. It does the following jobs: it extends the lens back and forth achieves focus by moving the lens zooms the lens by rotating them in the same time as the whole objective is moved back and forth Each of these operations is controlled by some servomotors who actually move these parts and are also connected to some sensors that pass the readings back to a main processing unit. When you open the camera this processing unit will check to see if the lens assembly is able to do all of these 3 things. Failure to comply with even one of them will result in some error (lens error) or simply having the camera not opening. "Lens error" is a generic message, doesn't mean that the lens itself are damaged, could be the connector to their servomotors, sensor failure, some coils that are out of position and things like that. They are all related to the lens assembly. Because this is a VERY fragile part of any camera I don't suggest you to try a DiY repair because you can damage the lens even further. Even service centers have problems repairing this, most time it is done under a microscope and some times it simply can't be fixed. This problems occur most of the time in corelation with the camera being dropped or received some shocks but it can happen out from nowhere, just like that. I would recomand you to go to a service center. Try not the big ones that represent large corporations (because they are expensive), instead look for a smaller one. Tell them you have a lens assembly problem, ask them to make you a diagnostic and then ask for a cost estimate BEFORE they actually repair the camera. If the lens assembly is damaged beyound repair it will need to be changed as a whole, including all connectors, CCD sensor and so on. This could cost from $70 - $200 excluding labor parts that can be about $100. Therefore you should ask them a cost estimate. If your camera is still in waranty you just need to call one authorised service center to have it fixed for free. Good luck and please post back if you encounter any other problems.
Apr 03, 2007 | Kodak EasyShare DX7630 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
62 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
