Question about Canon PowerShot A570 IS Digital Camera
Camera says new batteries are dead
My Canon A570IS recognizes the new batteries and turns on, but within seconds the camera turns off and blinks ''change the batteries''. I am unsure the reason for this and if possible would like an explanation. thank you for your help!
  • 3 more comments
  • fara08 Jan 05, 2009
    I have the exact same camera same problem - i see many others online complain of it as well. bad camera i guess. if you find a solution please let me know.
  • John Wittnebel
    John Wittnebel Jan 07, 2009
    Yes I have exactly the same problem. Camera says to replace batteries, and fresh batteries are still rejected as dead. I've even got a volt meter to test the new and old batteries and it indicated that the batteries were fine. I think this seems to be a common fault that Canon should address.
  • Enzi Mar 07, 2009
    same problem and I even replaced the button battery. still the same. I also have to input the date every time turns on! It does not file the pictures by chronological order either.
  • Anonymous Apr 20, 2009
    it just started to do this with my camera as well. Its terrible. Do you think i should get a new camera? or can any one help me with it
  • Pworld Apr 25, 2009
    I have the same issue with my Canon. It is going in the trash:(
I found out how to fix it. (STEP 1.) Take out all of the batteries. (STEP 2.) Hold down the power button for 30 seconds. (STEP 3.) Put the batteries back in and you should be all set.
Posted on Apr 20, 2009
  • catndog Feb 09, 2011
    This is only a temporary fix and does not repair the problem. You will probably have to repeat it often. This is a commonly know problem for this camera.
When I took my 4GB card out and put in a 2 GB it works just fine. No more low battery problems, Must have been a bad SD card, I was amazed how it was killing the batterys
Posted on Jan 06, 2012
  • James Penny Jan 07, 2012
I purchased a new laptop and it will not read the canon a570is disk. it gives me an error stating "the screen resolution to execute digital camera solution disk is not sufficient." help
No need to attention for it,just go on ,I have happen to this problem like this for several model of cameras,but it is just a OS mislead error sometime.By the way,confirm your battery for Canon PowerShot A570 IS is installed.
Nov 22, 2010 | Canon PowerShot A570 IS Digital Camera
Broken LCD on A570IS. Can I get a new panel? Quite capable of replacing by myself.
This could be a tricky one, the availability of parts will depend on the policy in the country that you live in. You should try Canon directly first, if they will not supply then you could try a local camera repairer who may have a good second hand one or be able to order the part for you.
Nov 05, 2010 | Canon Cameras
Hi, I have problems with my Canon powershot S5 IS, no matter what I do, my batteries are dead within 30 seconds. I've used a new pack of batteries to make 6 photo's. Anybody got advice?
it looks like the Camera Shortend the batteries
its a problem with the internal power unit one of the components is short and cause this problem
ecrdn@yahoo.com
Jack
Oct 20, 2010 | Canon PowerShot S5 IS Digital Camera
I have a new a year old canon a570is, not working,
If you have extended warranty coverage send it back. There are no user serviceable parts in a digital camera. Canon has been known in the past to cover some of their repairs if they turn out to be common. They also will usually give the option to customers to buy a refurbished camera of similar value in exchange for the broken camera at price that would be below the cost of actually repairing their camera.
Digital cameras are very complex and in many ways very fragile. I don't usually recommend extended warrant coverageexcept for digital camera's, if you can get it for the right price and are buying from a store you trust, its a good idea. You have to do your own math to see if this works for you.
Aug 09, 2009 | Canon PowerShot A570 IS Digital Camera
Computer won't recognize the Canon powershot A570IS
Norton antivirus or antispam maybe thinking your driver is a virus so it is disabling it and prevent it from working correctly. In order to be sure, disable your norton 360. and reinstall the drivers for your canon. If it worked correctly, the problem is 100% from norton 360.
In this case you have to call canon and norton tech support to help you.
Before you call tech support, try change the security level to a lower setting and try again
Good Luck!!!!!!!!!!!!!!!!!!
Jun 15, 2009 | Canon PowerShot A75 Digital Camera
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
Canon A570IS lens frozen half way-no power
I have a a570 IS that the lense locked out on. fixing it was going to be the same price as buying new, so I took mine apart and after two tries, i fixed it. I would be willing to take a look at it for a heck of a lot cheaper than Canon can if your willing.
May 22, 2009 | Canon PowerShot A570 IS Digital Camera
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
564 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
