Question about Lexar FireFly 2GB USB 2.0 JumpDrive
How to use Lexar Jump Drive
I just bought this Lexar Jump Drive Firefly 2GB. How do you use it? I try to save music to it by clicking save to it and I can not get it to work. HELP ME....
  • Anonymous Jan 06, 2009
    I don't have a clue how to use the lexar jump drive firefly 2gb. There were no instructions with it when I bought it. I think everything should contain instructions when you buy it.
4 Suggested Answers
aminic
  • 61 Answers
SOURCE: SanDisk 2GB microSD error message - Disc is Write-Protected
Re-format it. Put the SanDisk 2GB microSD memory card into your LG enV2 and format it from there. If that does not work plug it into your laptop then right click the icon and format it to FAT and click on default settings.
Posted on Sep 21, 2008
SOURCE: Please show me step by step on using the Lexar 2GB
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
Posted on Jun 20, 2009
laikexpert
  • 281 Answers
SOURCE: Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 08, 2010
SOURCE: Hi there, I'm having problems opening the files
If you have files on the stick and it asks for formatting, the file system is probably damaged. Try a quick format on the USB-stick. DO NOT save any files to the stick. Use a file recover tool on it, like example: Piriform's Recuva. Use the Deep Scan function.
Posted on Aug 08, 2010
How to format Lexar JD USB
Insert the flash drive in a USB slot and see what drive letter gets assigned to it. Right click on the new drive letter and select format from the drop down menu. Follow the directions on the next screen to format the drive.
Aug 23, 2014 | Lexar FireFly 2GB USB 2.0 JumpDrive
Storage issue LEXAR Firefly 4GB
Empty your "Recycle Bin", to permanently detect some "hidden" files on the JumpDrive.
If necessary, try a "quick-Format" to reformat the drive, deleting all "hidden" files.
Mar 03, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
All of a sudden no computer will recognize the
These drives do die from time to time. If a comp wont see the drive....it's dameged ...sorry. :(
Feb 19, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
I dont know how to save a writing piece from the word pad onto the lexar firefly
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
Oct 20, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Hi there, I'm having problems opening the files on Lexar 2GB JumpDrive FireFly it just says not formatted do you want to format? Please help I have precious photos etc. Thanks
If it says that the files are probably gone, sorry. Try using it on a different system, if it says the same thing they are definitely gone. Good luck I hope it works on a different system.
Aug 14, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
JumpDrive FireFly (4gb) not showing up in windows explorer or disk management
do you hear the USB hardware installation tones from windows when you plug in the the drive? If so then you are know the USB port is working. If you do not..try other USB ports. If you hear the noise...Right click on My Computer and click on Manage. Click on Storage and then Disk Management...see if you are having a conflict of drive mappings (i.e. F:/ or E:/)..you can relable the drive letters by right clicking on the drive in the right pane and selecting Change Drive Letter.
Jul 11, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Flash drive instructions
If you are using Outlook then you can double click the email so it is in it's own window and you can click File and Save As...
Then drill down to the Flash drive you want to save it to.
you should be able to do the same with Internet Explorer type emails.
Apr 08, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Please show me step by step on using the Lexar 2GB JumpDrive FireFly flash drive. I have an HP computer. I need to back up many photos. I will buy more of the same flash drives if I learn how to use them....
Feb 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
1.
2.
3.
Dec 28, 2008 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Lexar FireFly 2GB USB 2.0 JumpDrive Logo
219 people viewed this question
Top Lexar Electronics - Others Experts
laikexpert
laikexpert
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
