Question about Xerox CopyCentre C20 Black and White Copier
Xerox c20 doesn't print. the paper runs through & comes out blan
I purchased this machine at an auction and it appears to be brand new. I purchased a new toner for it and installed it. However, when i try to copy i just runs the paper through and comes out blank. It does the same thing if I try to print a report from the menu. Any Ideas?
  • walltowallsa Dec 29, 2008
    thanks for your response. your instructions pointing to the drum unit made me look for the drum unit and realize that it was not there. so i have ordered a drum and i am sure that that will fix it. so thanks again for pointing me in the right direction.
    all the best
    andy
  • tawkdavis4 Jan 15, 2009
    The copier runs, however it does not print,I have replaced the drum and toner an other suggestions!
    President:
  • Xerox Master
  • 990 Answers
Hello sir; you said this one is brand new, did you follow the installation instruction, no matter what, just di it again,
1, press "menu" ,
2, press up/down arrow keys until"new drum" display
3, press "mode/enter"
4, when you see"new drum unit?" press "1" to select "yes"
5, turn power off and on .
Posted on Dec 28, 2008
After all checks and maintenance on a xerox copycentre c20 the copy is still blink.
Will it still run the billing meter report? Is there print on the paper when you print the report?
If so, the issue is with the scanner. If not then the issue is the laser.
Feb 07, 2011 | Xerox Office Equipment & Supplies
My Xerox CopyCentre C20 doesn't always print the entire page, as if it is only scanning part of the page. It happens when the original is placed on the glass surface as well as when the original is sent...
the paper size detector may not detect the original size of the document check the paper tray indicator light on the panel and make sure the direction is the same with the original document onthe glass
Aug 26, 2010 | Xerox CopyCentre C20 Black and White...
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
I need Know, How enter to service mode
Press,,,,, Menu #1934 . What you may want to try first is to do what is called the Shading adjustment. That calibrates the scanner.
It would be found in the maintenance menu after you enter diagnostics.
You must place 5 pieces of white paper on the glass before you perform the adjustment.
There really is no way to increase the amount of toner concentration on that machine. You may very well have a defective ink cartridge. That is not uncommon on the C20. There is a metering blade in the toner cartridge that often times does not allow enough ink to be applied to the toner roller.
May 13, 2009 | Xerox CopyCentre C20 Black and White...
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
No toner light is on
Have you simply tried shaking it front to back vigorously? If you have and I am assuming you did that. take it out, and on the top of the cartridge you will see a clear round window. Take either some black tape, or a small piece of paper and tape over it and see what happens. How that machine determines if there is or is not ink in the cartridge is by a sensor that looks throught that window for toner.
If you block it and it still says out of toner, then your sensor is bad.
Jan 21, 2009 | Xerox CopyCentre C20 Black and White...
Xerox Copier Model XC1020
if the paper is black and the copies are coming out there is a problem with
1) the drum,
2) the transfer unit--- the unit under the drum, with thin wires,
Jan 08, 2009 | Xerox CopyCentre C20 Black and White...
Xerox Copycentre C20 Prints nothing but blank pages
Is the paper (copy) truly blank? Please look very close at the page. It sounds like the coratron (charge) wire (s) are broken. These are thin wires this use electrical charges to transfer the image onto the paper. You can go online and order a small spool of the wire and restring the wire. You do not have to be a doctor to do this repair but a steady pair of hands is very good. NOTE:::::: pay attention, most of the coratron units use tiny springs... so look and listen in case it falls out. You can restring with out the spring but it is better with the spring. Remember when stringing the wire, not loose but do not over tighten.
Dec 26, 2008 | Sharp AR-M455N Copier
Not printing full A3
Make sure the machine and the driver are set for A3 . Most likely the paper tray, or setting in the menu are not correct.
Or the driver paper size is not correct.
Jan 31, 2008 | Xerox DocuPrint C20 InkJet Printer
Xerox CopyCentre C20 Black and White Copier Logo
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
