Question about Cameras
Camera 10 months old..URGENTLY need a a plug in battery charger
URGENTLY need a plug in to mains battery charger, camera not usable at momet. supplier please ??
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
  • 319 Answers
SOURCE: Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Posted on Aug 01, 2008
  • 56 Answers
SOURCE: Samsung L100 cant figure out how to
you can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Posted on Jul 03, 2009
  • 16 Answers
SOURCE: Battery low
Check the green LED on the charger adapter - could be the fuse blown. Also check green LED on top of device - should be on when charging.
ALso, on the route confirmation screen, it shows the battery level, and if it is charging. Try wiggling the power jack and see if it makes a difference.
Posted on Jul 12, 2009
rapidfire360
  • 16 Answers
SOURCE: Battery not taking charge working while plugged in
more than likely the battery yes !
Acers arnt the best batterys in the world altho overall pretty good machines :-)
Im gonna guess you have been using the laptop almost always with the power lead plugged into the mains ??
everybody does it but they dont realise 1. it wrecks the battery & 2. worst case scenario is it burns/melts the solder connections of the jack plug (the socket where you plug the charger into ur laptop) inside, (where it connects to the board of the machine :-( )
this is a real big job to fix & can easily be avoided by just not using the machine on mains power all the time ! batterys should be 'Conditioned' from time to time for long life & reliability & the easiest way to do this is to fully charge then use the laptop on battery power until it just about shuts itself off due to low battery !! fully charge again (whilst not using it/switched off) & do the same again ! do this about 4/5 times every other month (or more frequently if u use it a lot??) & u will get maximum reliability from ur battery pack :-)
if the battery is goosed (which i would put my money on) take it off & record the Model Number of the battery (which will be on a sticker on the underside) & if funds allow buy a decent one (false economy the cheap ones as they dont last long)
When looking for a new battery (if using the 'bay' shop??) make sure the Model numbers match & dont search for a battery using just the model of ur laptop as sumtimes other model number batteries (from other machines) will fit but wont give the correct perfomance depending on the spec of the machine you have ??
hope this helps :-)
Posted on Feb 17, 2010
I have been made to do this my DCR-SR30 SONY HADDYCAM WONT CHARGE I MADE THE usb one is it any good
the USB charger is not usable, you will get separate charger in the market fit the battery on this charger,plug in this will be helpful.
Mar 03, 2016 | Sony Video Cameras
Digital camera batteries go bad?
Yes the can go bad.
I still have 9 year old Kodak lithium batteries in good condition, nut I know sometimes my rechargeable batteries last no longer then a year. It is a shame that some camera brands only give a 90 day warranty on the batteries.
To keep your rechargeable batteries in a good condition, give them a charge at least every 3 months. Or always a day before you need the camera. Never try to use speed chargers. I still have a charger capable of charging full within 15 minutes. The barrettes are hot, and when charged that way after 10 or 20 times they are dead.
Just use the charger that came with your camera.
But if you only can shoot a few shote with your battery, buy a new battery.
Jul 12, 2014 | Kodak EasyShare Cameras
Camera tells me it's no longer a usable battery
You may order a new battery (with charger) from here.
Feb 23, 2013 | Cameras
The lights are on showing that it is charged but will not go. It is only 10 months old.
If the charger is left plugged in longer then 24 hours you may over charge the batteries and they will not work properly. Also You must charge the batteries once a month even if it hasn't been used.
Lift up the back end of the gocart and see if the wheels spin when you pull the throttle. If you only get a clicking sound start by replacing the control modulator. 10 months old your batteries should be still good unless you over charged them. (Leaving plugged in longer then a day) Good luck...
Nov 16, 2010 | Razor 300001-SL Ground Force Go Kart
D363 new battery new charger still does not work the small coin battery is old cr 2025 what you advise battery chargerlight will not come on.
I have this camera, and have had trouble with connecting the charger to the mains (in the UK, using an adapter to plug the two round pin charger into a UK square pin socket). I found I had to withdraw the plug from the mains adapter socket slightly to get it to connect. Once it is powered, the charger light on the camera should flash while charging, and go on steady when fully charged. It takes a few moments to start flashing. It does not flash when the battery is not present, or when the camera is turned on, in play or record modes.
If it isn't a problem with the connection, perhaps the battery has reached the end of its life. Discharging the battery completely can shorten its life. Or perhaps the battery itself isn't connecting because it isn't seated in its mount correctly.
CR2025 coin cells are not hard to obtain- I have seen them in a local thrift mart and on eBay. I don't think it needs this battery in order to charge the main one, but it is worth a try. This battery is just to back up the memory of the settings and keep the clock running.
Oct 25, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
The batteries does not hold the charge.
A few solutions for you:
1) The batteries that you are using may have reached their end of life.
2) You are using higher capacity batteries in a charger that was designed for lower capacity batteries. The charger may be a 1 hour charger that was designed for say, 1500 mAH. If your batteries are 2000 mAH, then after the same hour, the batteries may not have a full charge, and will be damaged if this were the case, and the practice continues.
3) You are using a combination of batteries and charger that isn't compatible. For example, NiCD chargers cannot charge (usually) NiMH batteries, and vice versa.
4) There is always some drain by the batteries themselves, just being rechargeables. Though, this is usually on the order of 5-10% per month, and probably is not the issue.
I would put my money on saying that the batteries are worn out. Try a new a new charger / battery combination. If that works, then either the old batteries or old charger are defective.
Sep 15, 2009 | Canon PowerShot A590 IS Digital Camera
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
