Question about Kitchen Ranges
GE XL44 Gas Range; OVEN not working
My GE XL44 Gas Range Oven does not work but the stove top does (I think its only 4-5 years old).
Can someone tell me why this happened? Please email me at r.mchale@comcast.net.
Should a service call be placed or is this an easy fix that I could take care of? I have a GE XL44. It is almost 10 years old. The burners are OK, but the oven does not work. I turn the knob to the highest setting and/or to broil, but threre is not even a sound that gas is coming out.
  • alberi41 Jan 01, 2009
    The burners and the clock work. How do I check if the problem is with a fuse (power)?
  • alberi41 Jan 03, 2009
    The pilot light is not on.
    Genius:
  • 1,199 Answers
You need to have the ovens thermostat replaced! this is why it will not work! the stovetop does not use a thermostat and that is why it still works!
Replace thermostat!
Happy New Year!
Posted on Jan 01, 2009
    Brigadier General:
  • 5,158 Answers
Are you able to see if the pilot light is on for the oven ?... i would presume there would be a seperate one for the oven as well as the stove top.
Robert
  • Roberta Smith
    Roberta Smith Jan 03, 2009
    is there anything preventing you from relighting the pilot light... if so will it stay on ?
    Robert
    Genius:
  • 1,550 Answers
Did you check the fuse ?
Is your oven getting proper power supply .
Posted on Dec 28, 2008
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 oven does not heat
12 years old? If it is a gas rnge yo need to get a gas technician out to fix it. I would probably say it s time for a new one. Hers is a couple of things to think of when getting a new stove. 1) Everyone wants a self clean. But 90% never self clean. can save up to $200 w/o that option. 2) 80% off people buy a stovebased on looks. A stove may not be pretty but work just as good as one that is.
Feb 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 Gas Oven Bottom Heating
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
GE Profile Spectra XL44 oven wouldn't light, stove top and broiler works
We have our second GE stove and it has started to do the same as the rest of you.  Our first stove began to suffer igniter issues after 4 or 5 years.  I called GE and was given a simple test procedure for the igniter using a multimeter that I don't remember and likely wouldn't post regardless lest someone do things incorrectly... In any event, as I understand, the gas flow is tied to the igniter temp.  As the igniter ages, the temp that it can achieve gets lower. Eventually, it hits a point where the temperature isn't sufficient to reliably ignite the gas and our problems start.  The solution is fairly simple.  Replace the igniter. So, call a repair person and tell them the problem.  They can come out and instal the new igniter.  Unless you are a licensed or certified repair person, DO NOT DO THIS YOURSELF.  Let the pros handle repair to gas appliances.
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top works bottom doesn't
I have XL44 oven JGBP26. I replaced the glow ignitore on the oven but still will not glow. I carfully tested the current to the ignitore and showed 125 volts, I also tested the resistance on the control valve lead and to ignitore and showed 1100.
Dec 15, 2007 | GE JGBP28 Gas Kitchen Range
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
294 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
