SOURCE: Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
SOURCE: Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
SOURCE: servis 1200A caress washing machine trips electric
A wiring harness may be loose and the vibration has worn through the insulation. Put it on the side and take a look for loose wires and rubbing.
SOURCE: why does my washing machine trip the electric
Someone with a wattmeter needs to read the wattage load by the machine when washing. If the running load is greater than the rated load of the machine, then the problem is likely the motor itself or the drum bearings are going bad. If the electrical load is normal, then the breaker in the house electrical panel is either under-rated, or the breaker is defective. If the breaker is a 'ground fault' type, the washer may have current leakage to ground causing the breaker to trip. Another possibility is that there is another outlet that is on the same circuit and the combined load trips the breaker. Shut the breaker off and try any other sockets in the area to see if they went dead too. Hope this helps!
SOURCE: Kleenmaid kfl1600 front loader, does not start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
