Question about Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive
System not detecting my external hard disk
I have a MAXTOR 1 TB harddisk. last night i backed up some of my files and turned off my laptop(i dint use the 'remove hard drive' option since i was shutting down my system). I connected my hard disk again today but my system is not detecting anything. I tried connecting it to another system but even that dint detect anything. The hard disk is externally powered and the power led is illuminated and i can also hear the the disk running.
  • Anonymous Jan 12, 2009
    I own a Seagate 80 GB HDD, PC is not detecting it though the last is glowing and the HDD is fetching power from the system
Try going onto computer and see if it has removable disk right click and open or try putting usb in another port or if a disk came with it put that in .
Posted on Dec 28, 2008
The external hard drive (1 TB) started making a noise last night. It was still working. Today it is still noisy and will not show up on explore at all.
Your hard disk is damaged. The data you have on the hard disk could have been recovered when it started making noise. Looks like crashed heads of the disk. If it is under warantee, take it to the manufacturer for replacement.
Sep 21, 2011 | Samsung Computers & Internet
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
My desktop model is Compaq SR5213 with 250G harddisk. Recently, I would add a new internal hard disk (3.5", 1 TB), is it possible? As I don't want to buy a external hard disk. thanks
You can add 1 TB hard as additional to 250 GB Hard disk. You did not need to buy a external hard disk. Both hard disks will work together and make total hard disk space- 1.25 TB.
Aug 04, 2010 | Compaq Presario 5000 PC Desktop
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Hard disk not detected
You can't do very much, the damage is already done. The only thing you can do is to remove the hard disk from the case, put it in a pc and try to access it from there - most likely you will have to use a recovery soft to get some of your files back. Once that's done test the disk for faults using HDTune, the free version. If it reports errors, even small ones, then it's dying (or already dead) - junk it and buy a new one.
Jun 01, 2010 | Western Digital My Passport Essential SE...
HDD Maxtor 80Gb IDE: Harddisk error! At boot it say's Primary harddisk error. Press F1 to continue. *When I press F1 nothing happens. *When I go to the bios at IDE Configuration and hit refresh at Primary...
OK the only shot you got is to geta USB to SATA/IDE converter dongle, connect to another PC's USB port. Hopefully, you will be able to read it. Otherwise still plugged in you may be able to use recovery software and get you DATA back. Recover my files is one,
http://www.recovermyfiles.com/
Other freeware data recovery software GL.
http://www.freebyte.com/filediskutils/
Feb 15, 2010 | Maxtor Hard Drive
External hard drive is not detected
My Book Essentail Edition does seem to be working fine. the problem is I do not have access to the storage space in "my computer" or anywhere else as far as I can tell.
Jan 31, 2010 | Western Digital 320GB MyBook External USB...
I have a Acer Hard disk D110 1 TB what should the transfer rate
Acer D110 External Harddisk 3.5" 1 TB
USB 1.1 / 2.0 compatible
480 Mbps max
USB powered
Oct 21, 2009 | Acer Computers & Internet
Maxtor external harddisk recognition problem by pc
Hi Maxtarm,
It sounds like either the drive or enclosure is failing rather quickly.
The first and cheaper solution is to take the drive to your local computer shop and have the techs there move the harddrive into a new enclosure and test it. If it works in the new enclosure, you're done, but please take my advise and never rely on a single copy of your files. Always keep your important files in 2 or more places, on your computers hard drive, external drive and a backup to CD's or DVD's you can store in a firesafe or friends home is a good idea.
Now assuming that change of enclosures doesn't work, you will need the help of a recovery pro to get your files back. If that is the case comment back here with your location (Country, state, city) and I will advise you on a reputable recovery provider in your location.
Hope this helps Fixya,
Chris
Jul 15, 2009 | Maxtor Computers & Internet
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive Logo
559 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
