How to reset
You need to access the FSS menu, you get to the FSS screen by bringing up the status on how many miles to the
next service.....then hold the reset button for five plus seconds and that
brings up the FSS Main Menu. Trying to access the FSS by bringing up the outside
temp screen just doesn't work on my vehicle. I was then able to follow my
owner's manual directions to reset the FSS Service Indicator.......I got service
at a 3rd party Euro Service Center and they hadn't reset the FSS so I was able
to do it myself by using the above access process and then following my owner's
manual to do the reset protocol.
__________________
SOURCE: how to reset service light on a 2006 mercedes e class
1 key on #1 position
2 go to mph display in the cluster
3 press trip odometer knob three times (QUICK) voltage will appear on display
4 Select service menu using + or -
5 Service Indicator Displays Items
6 Press the menu systems button until the MPH display appears
SOURCE: how do i remove the service light on c class 220
hold down the trip meter reset button and turn ignition on then using radio volume controls on steering wheel the read out changes on the dash and you can then reset the service light
SOURCE: HOW DO YOU RESET SERVICE LIGHT ON A 2006 RANGE
reset service light. The SIA information is stored in the instrument cluster EEPROM and can only be reset by using T4. (Dealer tool)
SOURCE: how to reset the service light on my 2006 c230
disconnect the battery for 30 sec. then reconnect. this clears all trouble codes and will turn that light off.
