This sounds like you accidentally hit the input button on your remote. It will either be INPUT or SOURCE on you remote. Turn on your TV and source(cable box) and hit one of those buttons until your picture comes back
What brand/model TV do you have? If the TV has several input options, make sure that the TV is set to the TV mode. (Use the Input or Source button on the remote, some TVs have this on the TV as well but not always)
Some can only do a channel scan with the original remote. My old Emerson CRT (~20 years old) launched a channel scan when I pressed the Add and Delete Channel buttons together on the remote. Fortunately even when most of the buttons failed on that remote, the channel scan still launched.
Other TVs from that time frame have an channel scan button in the control panel. Often these are hidden behind a panel to avoid accidental resets.
More modern TVs usually have the scan as part of the menu. Depending on the TV, press Menu on the remote (or if available on the TV (sometimes can be done by pressing Ch+/Ch- together)). Then look for a Setup option or a TV icon. If you have a Setup menu, you will then need to go to the TV submenu. Then find the option for setting the input signal (TV/cable) and then you should be able to launch a channel scan. (Usually the Ch+/Ch- (up/down) and Vol+/Vol- (left/right) buttons will navigate through the menus.)
Unfortunately, without the make and model, I can't give you any more help. Please write back with your brand of TV and I'll check if I have the manual in my stack.
Cindy Wells (low end universal remotes do not always include the menu or source button. If your TV doesn't have them, you may need a different remote. The ones that can be programmed via a USB connection are the easiest to set up.)
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
