Question about Kenmore 24032\24036 Top Load Washer
WASHER WILL NOT SPIN
MY WASHER WILL NOT SPIN SOMETIMES AND I HAVE TO PROPT THE LID UP AND START IT SPINNING BY MY HANDS ON THE SIDES AND PUSHING IT AROUND TO START IT SPINNING AND THEN IT STILL DOESNT GET ALL THE WATER OUT. SOMETIMES IT DOESNT EVEN SPIN FAST ENOUGH TO GET THE SUDS OUT.
  • Anonymous Jan 31, 2009
    My washer doesn't spin.
Belt replaceing diagram
Posted on Feb 01, 2009
  • Kenmore Master
  • 8,220 Answers
Replace the belt
Posted on Dec 29, 2008
Doesn't spin during spin cycle
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes.
PLEASE CHECK OUT THIS LINK, THIS WILL HELP YOU OUT COMPLETELY.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Hope this helps. Mike
Oct 20, 2011 | Kenmore 24032\24036 Top Load Washer
Samsung b144s not spinning
Oct 19, 2011 | Samsung WF337AA Front Load Washer
It wash and evacuate the water but doesn't spin at the end!! What can I do?
What happens over time is the lid gets a little bent from use , reason it wont start unless lid is put down is because there is a lid switch that is called a safety switch, you might have to bend down lid some or this: Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike
Sep 09, 2011 | Washing Machines
I have a Kenmore washing machine: Model 110 20722990. When it gets to the final spin cycle sometimes it works sometimes it doesn't. You can hear it going but the agitator is not moving and it does...
ok first, i need you to do a little test,,,put unit on final spin ,does it spin at this time ,,yes so pick the lid up every so lightly ,,did it stop ...put the unit in final spin again unit does not spin push down on unit lid and it spins..in both cases you have a bad lid switch.,,the part # is 3949238 the picture is how it look,,if you need help installing just repost...good luckonthejob5130_1.png
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Washer wont operate even with lid shut. I have to push on lid until it starts.
Sep 09, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Machine wases & epties just wont spin motor ok brushes around 20mm long filters all cleaned not sure where to go next?
Hello there,
Jul 27, 2011 | Washing Machines
Washer works fine but no spin cycle
Hello there,
Jul 27, 2011 | Kenmore 44042 Front Load Washer
Water is now filling, washing going round in drum but not rinsing or spinning.
Spinning and Rinsing require a safety switch to be enabled by the closing of the washers lid.
Check around your lid and washer lid opening to find the mechanism that is used to activate the safety switch mounted just under the lid opening inside your machine. Sometimes it is a plastic plunger(protrusion) on the lid that mates with and opening(hole) in the machine around the lid opening to cause this switch to close. Other times it is on the hinge side of the
lid and the protrusion is formed right into the metal of the lid itself to push a plunger on the hinge side to close this safety switch.
Most spinning problems on machines are cause by this lid safety switch. Washing machines cannot spin if the lid is not closed and this safety switch is not working to switch power to the spinning motor.
Aug 30, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washer does not drain and spin
If this a whirlpool brand washer, check your lid switch. When they start going bad, they can be intermitent. While the washer is in the spin cycle, if there is no motor noise, push down on the lid above the lid switch and see if it starts.
This is the most common issue.
I hope this helps
Vic
Jun 20, 2009 | Washing Machines
Kenmore washer will do everyything but final rinse
This is a very typical symptom of a lid switch that is either broken or has come loose. If your lid switch is mounted on the right hand side of the lid, make sure the mounting screws are tight and the lid strike is in place (this is a plastic piece on the lid that activates the switch when closed). If your lid switch is on the left hand side in the rear under the washer rim (out of view), you may have to adjust the rod that activates it. For instructions on how to access the lid switch and/or replace it, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you need further assistance, please post back and let me know. You can also go to my profile and use the "Ask Me" feature for a quicker response.
May 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
142 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
