Question about PC Chips M955G Motherboard
PC Chips M955G Motherboard Front Panel Pinout
I am looking for a diagram to tell me how to hook up the power and reset switches and the leds
Nesesito los controladores de esta tarjeta madre  PC Chips M955G Motherboard x favor diganme co obtenerlos
Posted on Nov 30, 2008
    Novelist:
    Scholar:
  • 104 Answers
The image with this post shows the exact pinouts(Remember that pin one either has a little one beside or has a white indicator), u could also download the full manual here: http://64.124.27.138/pcchips/manual/m955g/M955G_30B.pdf
Posted on Apr 26, 2007
CóMO PUEDO ACTUALIZAR EL BIOS DE LA BOARD M955G, YA QUE EN DRIVERGUIDE NO ESTA LA ROM PARA PROGRAMAR LA PLANTILLA DE ACTUALIZACION, SE SUPONE Q ESTE PUEDE SER EL ARCHIVO M955G--- ROM PARA PROGRAMACION ES SUPONIENDO, 090407.ROM.
HOW I DO IT, BIOS UPDATED FROM THE BOARD M955G, SO , DRIVERGUIDE´S DON´T HAVE THE UPDATED ROM PROGRAMMING FOR THE UPGRADE ? -- WILL BE M955G -->090407.ROM --- I SUPPOSED.
William Henry G. mail wmhenry7@hotmail.com
contact me, write me. contactame escribeme. gracias trhanks you.
Posted on Aug 04, 2008
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
Pin connection front panel power switch
The only place to get it is from IBM, as it was designed specifically for them to go in their ThinkCentre A50 line of computers.
The link for the User's Guide, which is what I presume you need, is:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55533
If, instead, you want the Hardware Maintenance Manual, it can be found at:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55532
Finally, if all you desire is the Quick Reference, go to this link:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55534
Now, just to be complete, though I doubt this would do anything to help you, here is the Setup Poster:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-55595
Jan 03, 2013 | Lenovo D865gkd Ibm Motherboard Mpga478b
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
Jan 03, 2013 | IBM Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
i suggest to find in website..www.Fixya.com
if not found..post it again so that we can suggest another site.
thanks
Jul 25, 2008 | Mercury P4VM800M7 Motherboard
Hooking up to a EP-8KDA3J Motherboard?
You can find the online documentation on the manufacterers website; http://www.epox.nl/english/products/motherboard/8kda3.htm Their server is extremely slow however, so you may find this more useful; The file is 7.5MB http://temp.it-mate.co.uk/Epox_mu-8KDA3J_11.pdf Downloaded from DriverGuide (requires free membership if you want to download it from there yourself, instead of my server); http://members.driverguide.com/driver/detail.php?driverid=454065
May 23, 2008 | PC Chips M955G Motherboard
PC Chips M955G Motherboard Logo
2,357 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
