I've tried everything to fix Windows Updates failing and cannot get it right with all Microsoft fixes and their help desk. Can anybody help?
Click start type cmd press enter then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive you should have no input while chkdsk utility is in progress any input might further damage your computer or Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow hope this helps
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Testimonial: "Hi Brian I found another wonderful solution to these sorts of problems. Just download a torrent file that has all the current service packs and updates already included. I knopw it isn't quite legitamate but if you have bought the product and their friggin updates msee things up, why spend hours and weeks sorting out the underlying system when it should function and flow flawlessly. If you've paid, go get a pre-cracked version. It has wiped this problem from reoccurring."
SOURCE: Windows Installer 3.1
I have found a web site with a procedure to repair your Windows Installer... http://wiki.williams.edu/display/docs/Windows+XP+Repairing+Installer+Service Perhaps when this problem is fixed all the rest will fall into place.
SOURCE: WINDOWS UPDATE WILL NOT WORK IN WINDOWS VISTA HOME PREMIUM
Hey try to do this now
1: Open up "Control Panel" and navigate your way to "Programs and Features".
2: Click "View installed updates" on the left hand side.
3: Find the update KB929777 and uninstall it.
4: Attempt to install the update again in Windows Update
5: Once successful, restart your PC.
and if it works thats good but if it ddnt let me know plz
SOURCE: vista windows installer service corrupt
Download Installer manually from Microsoft. Install per instructions. Vista requires the "6.0" installer, as docs indicate.
http://www.microsoft.com/downloads/details.aspx?familyid=5A58B56F-60B6-4412-95B9-54D056D6F9F4&displaylang=en
Are you sure it's the Installer, though?, Are there event log entries that relate to the failures?
Fast & Easy Windows Update Fix. Takes Just 2 Minutes (Recommended)
PCHealthBoost.com/FreeDownload
Be sure to disable your anti-virus protection before checking for updates. This very well may be your problem.
or
I suggest changing the settings of your automatic updates as that may trigger it to do this for you.
Then disable any other programs that you can by right-clicking the icon in the system tray (next to the time, bottom-right corner of monitor) and selecting 'exit' or 'quit' or something like that.
If you are having a lot of trouble, you can get ahold of Microsoft at http://www.microsoft.com/protect/compute... too.
To change any settings related to Microsoft Update, go to http://www.microsoft.com/athome/security... .
Besides that, I recommend erasing the cookies and internet data. Click START > CONTROL PANEL > INTERNET OPTIONS. Then in the 'general' tab, click DELETE and erase all of the cookies and temporary internet files and such.
If that doesn't work, try rebooting your machine and tap F8 until you get the boot selection menu. Select "Windows Safe Mode with Networking". Try to go online again and see if you can download updates with that configuration.
If it still doesn't work, you can try disabling your browser add-ons that are installed in Internet Explorer. To do this, click START > ALL PROGRAMS > CONTROL PANEL. Open up INTERNET OPTIONS.
Click the GENERAL tab (if not open). Under "Browsing history", click DELETE... and then DELETE ALL. Put a check next to "Also delete files and settings stored by add-ons.". Click YES.
While still in the Internet Properties dialog box, click the SECURITY tab. At the bottom of the window, click RESET ALL ZONES TO DEFAULT LEVEL.
Now click the PRIVACY tab. Click the DEFAULT button (unless you are unable to). There is a good chance that it may be unavailable, meaning that you are currently at the recommended privacy settings already.
you might have to many programs trying to or accessing your computer or the internet at the same time or a virus
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now
download and install at least one of these all free depending on your operating system
http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
avg free 2012
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
hope this helps
error 50050008
Aaaa MORE replies! I will respond to all of them after trying them but for now, I can already reply to Brian. Will get back to all ya soon Thanks a mill :-)
This KB number stays the same Arthur. It's always 50050008 when I try to update Windows. Badi, there are no installed updates listed as I recently uninstalled all temporary traces or records of updates through a clean up programme of mine. Thanks for alerting me to this. I won't do that again as this is surely what has cased the problem. Windows doesn't have a record of what has been installed as updates. Not sure if there are any other causes but this must be one of them. Any other ideas of how to recover those or work around this?
Chris, thank you but that page has been deleted. THe message when going there says so. Are there any other sources to get hold of that fix please?
Ok Budi ... I tried uninstalling KB929777 another way. I did thisfrom the cmd prompt: wusa.exe. It came up with an error: Installer encountered an error: 0x8000ffff Catastrophic failure. lol Sounds DREADFUL! hahaha. Nothing has changed /uninstall /kb:976932
I'm not sure if I understood your KB question Arthur. I have run and installed a lot of KB numbers myself to try fix this through the Microsoft Fit It Centre. Do you want a list of them? None of them have worked.
