Question about Dishwashers
Error code on electrolux
I posted a pssible solution.  If yours has not been fixed yet, let me know if it works.
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear. Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08. Then hit the start button. My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
  • ttaylor07 Dec 29, 2008
    Thanks for the infomation on where the reset is.  The Electrolux support line refused to tell us where it was. They should have put it just behind the kickplate.
    Requiring a service call to clear an error code 1 is crazy.
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
Posted on Dec 29, 2008
What does 01 error mean?
Hello Ned, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "01". This error code means that a leak has been detected. Have you noticed any water coming from the bottom or near the dishwasher? This could also be a miscommunication within the control of the dishwasher and a reset may help clear that out. You can reset your dishwasher by disconnecting power from it for at least ten minutes. If that does not help to resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to some degree. -Matt
Jan 22, 2016 | Electrolux Dishwashers
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
How to fix error code 0.00
Based off the information you provided your Electrolux washer is displaying "0.00". Typically any error code that is labeled "00" means no error code stored, which means it's a false error code. I would recommend performing a reset on your washer due erase any false error codes. You can do that by disconnecting the power from your appliance, by either unplugging it or flipping the household circuit breaker, for ten minutes.
If this step does not help resolve the problem please provide me with the new error code or if your display continues to show "0.00" I would suggest seeking assistance from a professional to come out and properly diagnosis your washer. I hope this information is helpful. -Matt
Oct 02, 2014 | Electrolux Washing Machines
Have an error code 01 on my electrolux dishwasher
Good Morning Friend, I am happy to assist you!
Typically error code ER01 indicates that a water leak has been detected under the tub of your Electrolux dishwasher. Your dishwasher may possibly need a hydraulic kit. Try unplugging your dishwasher or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and turn on your appliance. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis. Best regards! - Z
Jul 20, 2014 | Electrolux Dishwashers
Error code 01 after problem has been fixed on electrolux dishwasher
I understand you are receiving an error code "01" on your Electrolux dishwasher, even after the problem was fixed. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Dishwashers
More than one error code 01 on electrolux dishwasher
I understand you are receiving more than one, error code "01" on your Electrolux dishwasher. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
What is an e64 error code on electrolux dryer ewmed70jss?
Good Afternoon Friend,
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Electrolux Dryers
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
May 20, 2014 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
Dishwashers Logo
984 people viewed this question
Top Dishwashers Experts
