Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Freezer comes off and on.
I have an upright frigidaire model MFUI7M36W1
I recentley moved it from my workshop into the house. I was working great in the workshop. Now it will work for 3 or 4 days and suddenly stop freezing. If I disconnect it for a short time it seems to restart again. But then eventually after 3-5 days it will stop??
Chet
  • 67 Answers
Try leaving it uplugged for at least 6 hours
Posted on Jan 07, 2009
  • 903 Answers
Try leaving it uplugged for at least 6 hours after it has been moved in order for the oil and gas to seperate and settle. Then it should work okay
Posted on Dec 28, 2008
Lost manual for my Fridgeidare upright freezer 20.5 with the controls on outside. what does 0F mean. and if I need to set it ,we just moved how do I set it?
Hey friend, thanks for your post!
From my understanding you have recently moved your Frigidaire freezer and it is now displaying the "OF". Normally, that stands for off you should be able to press the "Up" or "Down" arrow three times within five seconds to start your compressor. If you still need a copy of your manual could you provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I hope this has been helpful. -Matt
Oct 11, 2014 | Frigidaire FKFH21F7HW 20.5 Cu. Ft. Upright...
Do you have a manual for a Frigidaire Freezer upright with model number FFU1464FW1
Hello Lasondra, that's a great question!
I have successfully located the Owner's Guide of your Frigidaire freezer, FFU1464FW1. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Frigidaire Manual Search Results
Sep 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What size is a frigidaire freezer mfu17f3gw6 ?
Good Afternoon Claus, that's a great question!
Your Frigidaire freezer (MFU17F3GW6) has a total capacity of 17.0 cubic foot. I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Jul 12, 2014 | Frigidaire Freezer Refrigeration White...
Freezer lffu14f54hwc try to cutoff by holding down till 0 appears get e7 appearing
Hello Oran - Typically error code F7 on Frigidaire freezer indicates that the unit has detected a stuck key or fail safe mode initiated. Check if it has a thermistor failure and may possibly need to replace the main control board. Contact a professional to move forward accurately.
Oct 12, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Aug 13, 2010 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Frigidaire Upright not cooling
Not enough information but  if you are refering to the compressor as the black housing below, it seems that the compressor is either seized or burnt out.
Oct 25, 2007 | Frigidaire 11.6 cu. ft. / 328 liter...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
107 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
