Question about HP Compaq d530 PC Desktop
How to install new hard drive
I bought on a local government auction an HP d530 CMT. It's got a 2.80 GHz Pentium 4 CPU, 1.25 GB of RAM, a Maxtor 40 GB hard drive, 6 USB 2 ports and a CD drive with Windows XP Pro SP 3 installed. It came with no manual, no documentation and no discs.
For upgrades I installed: a XGI Volari video card into the single PCI socket to drive a LG digital monitor; an Intel dialup modem; replaced the CD drive with an old LG CD burner that was lieing around; then a new LG "Super Multi" DVD burner as a second optic drive.
Then my wife buys me Microsoft Flight Simulator I always wanted. It won't load due to insufficient room on the 40 GB hard drive.
(1) How do I install a new large hard drive since I have no XP discs?
(2) Should I just copy everything on the old drive onto DVD discs, install the new hard drive, then power up with the disc(s) in the DVD drive?
(3) Would it be better to leave the original hard drive alone and get an external USB drive?
(4) Would the Flight Simulator run well with my system using an external hard drive?
(5) What power source does an external drive use?
Thanks,
Mark
  • Mark
    Mark Dec 29, 2008
    Okay - you both suggest a 2nd hard drive - so a 2nd hard drive it is. The label on the existing one states: Maxtor 3.5 Series N256 DiamondMax Plus 8 ATA/133, 12V 79omA, 5V 647 mA 40 GB. There are 6 power leads and an unattached serial plug marked "Slave" (I swapped out the the factory cord with a sheathed ATA/133 one although I don't know if that'll speed up anything).
    (1) So what HDD is compatible?
    (2) Does the BIOS or something limit the size I should get?
    Thanks guys.
    Mark
    Novelist:
  • 124 Answers
Hi Mark,
External drives have come a long way and run almost as fast as many internal drives. If your need for extra hard drive space is pretty much driven by the Microsoft Flight Simulator game, you could get by with using an external drive. A few things, though: Make sure your system is supporting USB 2.0 (it should be) and that the drive runs at least 5400rpm. External HDD's run off standard 120v AC power.
Otherwise, if you want to get an internal drive, you can certainly get another ATA-133 drive. But SATA is faster and your computer may support it. The D530 CMT (convertible mini-tower) definitely does. But there is also the D530 SFF (small form factor), and D530 USD (ultra slim desktop)--not sure if those are rigged for SATA support.
As for maximum hard disk size supported, that's up to the operating system (e.g. Windows XP vs. Vista). You likely won't need any bios updates because of a new hard drive installation. However, its not a bad idea to review the BIOS update release notes to see what they're addressing.
Posted on Dec 30, 2008
  • Gary
    Gary Jan 05, 2009
    Mark, I have the same computer: D530 CMT. This computer supports SATA, which is a faster data connection than IDE. I suggest you buy a SATA drive.
    On the power cables, you will see a SATA power connector. It is black and about half as thin as the standard 4 pin power connector. On the left side of the motherboard, you'll see a very small circular component with a yellow dot on it, labeled for "CPU Reset". On either side of this are the SATA motherboard connectors. The one on the left is slot "0", which is the one you would use.
    What version is your BIOS? I have updated to 2.44 Rev. A, which was released on August 2008. You can obtain this from the HP support website.
    http://h20000.www2.hp.com/bizsupport/Tec...
    As for hard drives, I can't recommend a particular model. Many are good--you just need to shop around.
    President:
  • 1,179 Answers
2 choices for you. Get the external to run the game or 2. Add a larger hdd to the system as a slave drive leaving the smaller drive as the master. If you go the 2nd route just make sure you buy a compatible hdd. Hope this helps & please remember to rate my answer.
Posted on Dec 28, 2008
    President:
  • 2,692 Answers
1.You need HD clone software such as  truwe image home. 2. That wil not work.  3. I personally don't think so,if anything add an extra HD inside the        case set up as the slave. A lot cheaper. 4.Where the HD is located wwil have no effect on how that software        will run on your machine.  5.Mine has it's own transformer that hasds to be plugged into the 115V wall outlet.  I hope  iu have answered all that you have asked.
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
Sep 19, 2011 | Computers & Internet
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
Troubleshoot D530 Pentium 4, i get the boot screen, over n over
Run hard drive tests, if HD tests good, and no data to keep, restore os from restore partition with f10. If data needs kept, run a repair installation of os. Run fixboot and fixmbr commands from prompt. Also try sfc/scannow from command prompt.
Nov 21, 2009 | HP Compaq d530 CMT Intel Desktop PC -...
Can i upgrade my Ram and hard disk in my HP pAvilion dv4000?
according to the specs you can install up to 2 gb of memory and the manual states that a 100 gb hard drive was an option. not sure if you can go higher then that.
Robert
Please take a moment to rate this solution thanks
Jan 29, 2009 | HP Pavilion dv4000 Notebook
Does my d530 CMT have a SATA connector?
Answers to your questions:
1. Yes
2. Very likely
3. a Google search should show you what the connectors look like.
4 HP/Compaq do a good job of providing documentation. Go to hp.com and put in your system information. You should be able to locate motherboard diagrams there. If you can't let me know and I'll try to locate them.
Dec 29, 2008 | HP Compaq d530 PC Desktop
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Compaq d530 PC Desktop Logo
911 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
