Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I have no heat from my hotpoint aquariur ctd20 tumble dryer
The machine is working fine apart from no heat checked all the wires they seem fine de fussed the machine but i am unsure where the element is or what it looks any help would be great.
  • Hotpoint Master
  • 3,463 Answers
The element and stats are located behind removable panel at rear of m/c.
To test , you will need a multi meter set on the ohms range for continuity check., and you need to pull the wires of the components to get a proper reading.
THE M/C MUST BE UNPLUGGED prior to this check.
Check and clean all filters, remove the front bottom left filter, and clean by running under cold water.
Hope this helps.
Plz rate my solution
Thanks.
Posted on Dec 29, 2008
Hotpoint TCL 780G condensor tumble dryer
hi make sure heater element is not touching back of dryer causing a short or break on wire catching casing
Mar 05, 2014 | Hotpoint Dryers
THE WIRES MIXED UP ON MY TUMBLE DRYER HOTPOINT VTDOO TIMER
In most appliances I've had apart there is a stick plasic envelope stuck somewhere inside the cabinet or the control panel that contains the wiring diagram.
Nov 24, 2013 | Hotpoint Dryers
Tumble dryer has stopped working
you can check pump ,if pump isn't working water stay all time .
Feb 20, 2012 | Hotpoint Aquarius WD640 Front Load...
The heater in my hotpoint aquarius tumble dryer Model TDC 32P ceased to function and I have replaced the heater element with the correct model. However this did not cure the problem. The machine has been...
Sounds like the Thermistor is open. It looks like a dosc about the size of a quarter with 2 wires attached. It is a switch that turns the heater element on and off during the dryer cycle. It's a safety device to prevent overheating and if it's stuck open the machine will appear to work properly .... just no heat. Test with ordinary meter or continuity tester by removing the wires and checking across the device. Replacement is easy usually 2 screws and inexpensive ( less then $10)
Jul 20, 2011 | Washing Machines
When i press the start button on the tumble dryer it blows the fuse in electric box
Greetings,
This dryer could have several different things wrong with it and needs to be taken apart to check it....It could be the heating element shorted to ground or the dryer motor shorted out to ground...It could be an over heated wire that melted into each other..you need an understanding of how to check circuits if the obvious isn't seen...i.e. broken element or burnt wire....Bruce Denton
Jan 04, 2011 | Hotpoint Dryers
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Hotpoint tumble dryer model tdl62
you dont indicate if its gas or electric.
for both you may check the highlimit switch.
there may be two on ur unit depending on age.
they are located on the back panel and can be removed with a simple screwdriver. of course different models have different locations ..just poke around. (some are round disc others are plastic and both have a wire comming in and one going out of it) when they go bad they dont allow heat section of the dryer function (yea its a safety issue) if u have a meter test it, this should be a n/o switch if its closed...continunity (bad spellng) portion of the meter is used for this. simple check to do. you can do it with the machine off. email if you have more questios.
gl
k
Feb 27, 2008 | Washing Machines
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
