MOD 110 42922 022 TYPE 119-AKP 720/WT
See this causes and fix it. God bless you
If the washer won't start, check to be sure there is power to the
electrical outlet for the home. If that is OK, the power cord itself
might be defective. This is rare. You can check the power cord with an
Ohm meter for continuity.
If the washer won't start check to see if there is power at the
electrical outlet which the washer is plugged into. Plug a lamp or radio
into the outlet to check it. If the outlet is dead, check the circuit
breakers or fuses for the home.
If the washer won't start the door lock assembly should be checked. The
door lock can fail either mechanically or electrically. Test any
switches on the door lock with an Ohm meter. The switches should have
continuity according to their design.
If the washer won't start the lid switch assembly might be defective.
This is a very common problem. The lid switch assembly can fail either
mechanically or electrically. Test any electrical switches with an Ohm
meter for continuity. The switches should have continuity according to
their design.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the thermal fuse may have blown. It can be
tested for continuity. Watch our fuse testing video for more
information.
If the washer won't start the line fuse might have blown.
If the washer won't start the timer might be defective. This part is
often misdiagnosed, check other components before replacing this timer.
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
SOURCE: My Kenmore H3T washer will not start. When a
Hello, welcome to FixYa.
I will start by saying your post indicates it is a Kenmore washer, however if you could post the complete model number and the approximate age I can speak directly about your's instead of generalizing.
Hopefully you can appreciate there are many differences even within the Kenmore brand. On most the flashing light error indicates a "door open" scenario has occurred, (obviously it isn;t...right ?) but I'll need to clarify the model number before detailing much of course. I'll watch for your reply before moving forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
