Question about Acer AC713 17" CRT Monitor
Acer Vga crt monitor cable SOLDERING DETAILS - Acer AC713 17" CRT Monitor
4 Suggested Answers
SOURCE:
leroyal
  • 2120 Answers
SOURCE: ACER AL1715ebm LCD MONITOR BAD VGA CABLE
you are in a bad spot, the plug is sealed when molded. maybe ebay has a defective monitor and you could take the cable off it.
Monitors will usually snap apart with a butter knife.
Posted on Jan 28, 2009
swarupbanai
  • 111 Answers
SOURCE: ACER AC713 CRT MONITOR HOW TO SOLDRING 15 VGA PIN
Go to http://pinouts.ru/Video/VGA15_pinout.shtml for more details. Hope it helps
Posted on Sep 16, 2010
  • 3 Answers
SOURCE: Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Posted on Jan 30, 2011
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
Samsung syncmaster 794mg monitor setting
i want vga cable D connecter connection
mainly vga cable broken that why i purchage one emitty d connecter scoket so i soldering this connection plz
May 23, 2011 | Samsung SyncMaster 793MB 17" CRT Monitor
Shows different color complete blue or red scrren at connection
shake vga cable at different places & observe.........if colours becomes normal or it comes & again it goes...then vga cable is deffective.......either you have to change full vga cable or you have to repair that cable itself................after shaking cable also if no improvement then......hit your monitor lightly on left side or righr side or on top & observe ...........if colours becomes normal or it comes & again it goes...then following is the situation...............after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact colour problem comes (1 of the sympton) ...........when we hit that lightly then those loose contacts joins temporarly & again colour comes nomally for some time............so solution is ......monitor main board & crt circuit board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no improvement then..following is the situation.....................on CRT circuit board ( circuit board that is fixed to tube) ''red green blue'' - video output IC ( some thing like LM2469TA ) will be there - it should be replaced - usually it will be fixed to heat sink ------- before changing IC all the components on CRT circuit board should be checked ( after switching off monitor ).........this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good monitor service engineer .............iam from bangalore - 09986222774 - sathyavijayasarathibabu@ymail.com ( computers, laptop, printers, etc )
Apr 11, 2011 | SAMTRON 55V 15" CRT Monitor
My philips 104E 15" monitor is not displaying red colour at all.other two colours are perfectly OK.What could be the cause? is the red gun gone?
Yes, or the RED driver circuits is bad, check soldering joints on the CRT PCB. Simple thing to do is to check the VGA cable connection first, check the video card (reseating the card).
Apr 21, 2010 | Philips 107E61 17" CRT Monitor
Vga cable config wire colour
Are you asking a question? Do you want to make your own VGA cable?
Unless you are VERY ADEPT at soldering, please don't do this. You can get the color code by removing the molded cap on an existing cable and/or by cutting the end off and testing with a ohm meter. New "d" plugs can be purchased at Radio Shack.
Still, for the relative small amount of money a cable costs, if yours is removable, get a new cable that suits your needs. Failure to properly connect the new plug could be fatal to your monitor.
Thanks for your interest in FixYa.com
Dec 26, 2009 | GNR CM1997FS (Beige) 19" CRT Monitor
I have an HP Pavilon, Laptop and an Acer Monito
you can buy a lcd cable to connect your laptop and your acer moniter.
if your moniter is a crt then no need to buy you can use the default cable.
if its a lcd the cable is given in that package. you can use it.
you can see a vga port in your laptop with blue colour that is the connector for moniter and your laptop
Jul 14, 2009 | Acer AL1721 17" Flat Panel LCD Monitor
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Display green,red
It should be dry solder joints on the CRT board,the picture tube base is normally dry solder.
Opening the monitor could be tricky as there are two plastic locks which hold the top end of back cover.
Samir
Mar 09, 2008 | LG Studioworks E700B 17" CRT Monitor
Acer AC713 17" CRT Monitor Logo
27 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
