Question about HP Pavilion dv6000z Notebook
Computer won't work on wireless after reloading windows xp
The blue light will not come on.
No wireless networks shown on lower tool bar.
Computer works fine with a cat 5 lan connection.
  • PvtParts May 14, 2009
    my wlan switch is orange when it is off and turns blue when i litley tap it. on the screen it sais it is on yet the switch is still orange, plus i cant connect to anything.
    Sergeant:
  • 279 Answers
Many laptops come with a control key or button to disable the wireless radio to save power. First try looking to see if you find one, then turn on the radio. Post back with more info if that doesn't work.
Posted on Dec 28, 2008
    Sergeant:
  • 366 Answers
Switch Wlan ON
"The front of the notebook has the wireless On/Off switch, IR port, line in and out, and S/PDIF jack."
Did you activate it?
My WD 320gb external hard disk is not getting detected in computers...the blue light blinks on d drive & also in device manager the hard disk is shown....but cant get into it & itz not...
For windows 7 / Vista : - write "Administrative Tools" to start menu "Search Programs and Files" box and click enter - Double click "Computer Management" - Click on Disk Management under the Storage on the right. - If your WD disk is shown on the list at the top, right click it and select Change Driver Letter and Path - Select a suitable letter. - Try reaching to your hdd from My Computer
For windows xp ( or 7 and no results appear when you write "Administrative Tools" to start menu "Search Programs and Files" box and click enter)
  1. Right-click on an open part of the Windows task bar and selectProperties. The Properties dialog box opens.
  2. Click the Start Menu tab, then click the Customize button. The Customize Start Menu dialog box opens.
  3. Click the Advanced tab, then scroll to the bottom of the Start Menu items list and click the radio button next System Administrative Tools > Display on the All Programs menu and Start menu.
  4. Click OK twice.
  5. Click Start > All Programs > Administrative tools to access these tools.
Then follow the above (first) steps.
Mar 10, 2011 | Computers & Internet
I can not figure out how to get the computer to make a wireless connection.
Add the Home SSID to the Preferred Network List After you set the SSID on your home gateway, you may need to add it to your preferred network list if Windows XP Wireless Auto Configuration is enabled. (Although automatic configuration is nice to have, your IT department may have disabled it on your laptop in order to meet their needs. If they have, you'll need to use the tool provided by your laptop or wireless manufacturer to manually configure wireless settings.) To manually add your home wireless network to the list of preferred networks when Wireless Auto Configuration is enabled, follow these steps:
• In Control Panel, click Network and Internet Connections, and then click Network Connections.
• Right-click the Wireless Network Connection, and then click Properties.
• On the Wireless Networks tab, shown in Figure 3, click Add.
Figure 3
• In the Wireless network properties dialog box, shown in Figure 4, enter the SSID you configured for your wireless gateway (ExampleHome_g in this example.)
Figure 4
Note: Figure 4 assumes you've added the Windows WPA Client Update. If you haven't downloaded and installed it, you probably should. For more on the WPA Client Update, see Overview of the WPA Wireless Security Update in Window XP.
• Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway.
• Click OK and your home network will be added to the list of preferred networks.
Now, whenever you're at home, your work laptop should automatically see your home wireless network and connect to it.
Jul 05, 2010 | Acer Aspire 5100 Notebook
How to enable wireless for HP Pavilion ze4900?
Look at your laptop in the lower right hand corner on the front edge. The blue light. Just below the light is a toggle button (wireless radio switch). You should see a wireless symbol on it. Press it to turn ON and/or Press to turn OFF. See photo attached7_22_2012_5_01_02_pm.png
May 20, 2010 | HP Pavilion dv2000t Notebook
Have netcore310g adapter got cd. computer crashed had to reload everything now my wire won,t work, IT LOOKS LIKE DRIVERS WON,T LOAD -HELP. TRIED TO LOAD MANUALLY NO LUCK PLEASE ADVISE WHAT TO DO TRYING...
You will want to check in your device manager to see if the network card is not being recognized and you will be able to update the driver there.
For windows XP, rght click on my computer, select properties and then select "ahrdware" and device manager.
For windows VIsta and 7, go to your control panel and open Device manager there.
Once open, you should see a network adapter with a yellow question mark or yellow exclamation mark beside it.
In either case, make sure the driver disk is in your disk drive, right click on the network adapter and select "update driver"; then just select the "recommended" options and follow through.
If this still doesn't work, try uninstalling the device from the device manager and then install the drivers using the disk.
Thanks,
Pat
Mar 29, 2010 | Computers & Internet
Blue wireless light will not comw on
Ensure printer is off - remove all software connected to the printer - switch computer off and back on - reload software - reconnect -
If still does not work we have something else conflicting with the printer. Of course you also need a wireless network enabled with ur computer for it to work...
Jul 30, 2009 | Office Equipment & Supplies
Wireless physical adaptor is not installed on Dell Inspiron 9400
ah ok....just change the memory,if still the same change the hard drive....if it is still the same....during the setup of install xp!!! when blue screen just press f7...
Jun 30, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Wired internet working through netgear... wireless access denied
You must determine the wireless security of your router;
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
a. Click on the Wireless Settings under Setup.
b. take note of the SSID
c. if your using WEP...the network key would be on the key 1.
d. If WPA-PSK TKIP is in use just type in a new key with a minimum of 8 characters on the passphrase box. Please remember it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Apr 06, 2009 | NetGear WGR614 54Mbps Wireless Router...
I cannot connect my netgearWG111T wireless usb adaptor to my router
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting to the Wireless Network
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
Nov 08, 2008 | NetGear WG111T 802.11g/b (E82321) Wireless...
I have a Compaq PC with Windows XP and the flat I've moved into has wireless broadband - how do I connect to it?
You can use a wireless network to share Internet access, files, printers, and more. Or you can use it to surf the Web while you're sitting on your couch or in your yard. Plus, it's easier to install than you think.
There are 4 steps to creating a wireless network:
1.
Choose your wireless equipment
2.
Connect your wireless router
3.
Configure your wireless router
4.
Connect your computers
For Windows XP users, Windows XP Service Pack 2 is not required for wireless networking, but it does make things much easier. Service Pack 2 also helps protect you against hackers, worms, and other Internet intruders.
If your computer does not have wireless network support built in, plug your network adapter into your USB port, and place the antenna on top of your computer (in the case of a desktop computer), or insert the network adapter into an empty PC card slot (in the case of a laptop). Windows XP will automatically detect the new adapter, and may prompt you to insert the CD that came with your adapter. The on-screen instructions will guide you through the configuration process.
Note: The steps below only apply if you're using Windows XP Service Pack 2. If you're running Windows XP and you don't have Service Pack 2 yet, plug your computer into your wireless router and download and install Windows XP Service Pack 2.
Windows XP should show an icon with a notification that says it has found a wireless network.
wireless_connected.gifFollow these steps to connect your computer to your wireless network:
1.
Right-click the wireless network icon in the lower-right corner of your screen, and then click View Available Wireless Networks. If you run into any problems, consult the documentation that came with your network adapter. Don't be afraid to call their tech support.
2.
The Wireless Network Connection window should appear and you should see your wireless network listed with the network name you chose. If you don't see your network, click Refresh network list in the upper-left corner. Click your network, and then click Connect in the lower-right corner.
wireless_chooseconnection.gif 3.
Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
4.
Windows XP will show its progress as it connects to your network. After you're connected, you can now close the Wireless Network Connection window. You're done.
Note: If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key.
Nov 05, 2008 | Compaq Computers & Internet
WOnt connect
the model of laptop...if its Toshiba, hp or sony it likely has a switch on side of it.. or could be like dells fn and f2 keystroke (hold fn hit f2) a wifi light turns on then refresh wifi list. make sure u have at least 2 or 3 green bars in xp also if a tool took over the wireless configuration then it wont show any. (check box in advanced settings "let windows manage my wireless connections")
Jan 24, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
HP Pavilion dv6000z Notebook Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
