I replaced the water filter as per the instructions (I've done this a dozen times before) and now the machine won't complete the cycle of circulating water through the filter and out the steam port.
It's as if it can't prime the pump. I've even tried putting back to old filter in case the new one is defective but to no avail.
I can not this machine mark, but on other machines it can hang in system and then we have to start the programme again. Sorry i not can give you a clear solution on this case:-(
My S8 was off for about 2 years! Now I can't get the water to go through the coffee mode. I do get...
(More)
My S8 was off for about 2 years! Now I can't get the water to go through the coffee mode. I do get the tea potion and limited steam potion. Any ideas?
I have an Jura Impressa S8 and the coffee it produces has always had a slightly oily flavor (a...
(More)
I have an Jura Impressa S8 and the coffee it produces has always had a slightly oily flavor (a machine oil flavor). I have washed the machine several times by putting the tablet into the coffee grinder and that has not changed the result. I have also tried the unit with and without the filter, and different types of water (plain tap, distilled, externally filtered, etc). The oily taste is present regardless. I have also tried several different coffees from different sources (Peet's, Starbucks, other specialist producers brands, etc). The oily taste persists. Any suggestions?
I have run the clean process with the tablet 2 X , but the machine keeps beeping to be cleaned. I...
(More)
I have run the clean process with the tablet 2 X , but the machine keeps beeping to be cleaned. I use brita filtered water & thought to decalcify the machine for the 1st time. Maybe that will help, but do you use the liquid that the manual says(durgol), or the decalc tablets Williams Sonoma says to use? Anyone else have their machine want to be cleaned over & over?
Aftter 2 years, my Jura Capresso S8 has just developed the same problem. I use the Claris filters, so I doubt it is a problem with calcification. The time before this, it made me clean it twice and then the message went away, not it keeps saying "Clean Unit" no matter what I try.
I have to fill the system ,because I was some time away. I Filled the water tank. Then I pressed...
(More)
I have to fill the system ,because I was some time away. I Filled the water tank. Then I pressed steam, It is working some time, no steam comes out then it shows again fill system
