Question about Acer AL1912B 19" LCD Monitor
Input not supported
I would like someone to help me by letting me know how to fix my monitor which says input not supported, it comes on when I am playing a game on pogo all the time and have to shut my computer off and on to work.
My monitor is 17" Acer .
Please help me as I cannot afford to take my computor down to get it fix.
Thank you very much.
Heather Hay.
  • Anonymous Jan 04, 2009
    They have checked everything the drivers, video card, my fan incase of over heating and they also played the game of pogo to see if it did it for them, but nothing happen, and I have taken it down twice, and I have it at home and started to play my game and the same thing happen input not supported.
    What's the next thing I should do, or is it my monitor?
    hhay.
  • 903 Answers
Sounds like the drivers might need to be updated for the monitor and the graphics card. Most monitors install with windows drivers, so it could just be the graphics card that needs updating. What is the make and model of your graphics card
Posted on Dec 28, 2008
Why my Pc monitor showing Input not supported?
There are several inputs that a monitor can handle depending if it's capable of doing so. For example, just like TV, if you want to watch a DVD, you have to change the input to Video and going back to TV, just choose TV input. The same way for computer monitors. If the monitor supports VGA, DVI, HDMI and others, you have to select the right input depending of the type of Video cable connected from your tower to the monitor. If you it is connected via VGA, choose VGA input. If the cable is HDMI, select HDMI. That will let your monitor switch from one input to the other..
Hope that works for you. -
I'll appreciate the feedback and the thumbs up.
Thanks.
-jash
Apr 27, 2011 | Rosewill 19" 12MS DVI R911E LCD Monitor
How do i hook up my ps3 and xbox and get 720p, i have the dtv34xr
You would have to hook it up on the VGA input so you will need a component to VGA lead. I am not sure that the component input supports HD on that monitor but I think the VGA input does.
I hope that helps, Will you let me know how you get on please?
(If the picture does not lock on the monitor then I don't think there is much you can do as it will be that the refresh rate of the ps3 is wrong and as far as I know it depends on games/ regions and cant be changed. You would then need an expensive hdmi to vga converter, not worth it better to get a new monitor)
Jan 26, 2011 | NetTV DTV 34XR 34" CRT Monitor
HP L2035 OSD Lockout and DVI lockouts
change micro switch in frount panel all
Mar 19, 2010 | HP L2035 20.10" LCD Monitor
How do you connect a viewsonic vg15ob mo niter into my labtop
Chances are you laptop has a vga input (looks like a blue trapazoid with lots of holes). Most monitor come with a vga cable. If this is the case you are good to go. If you dont have a cable for the monitor, you need to look on the back to identify the type of input(s) you have (DVI,VGA, or RCA). Then go to your local electronics store and tell the guy/girl you need a blank (monitor input TO blank (Laptop output) and you should be in business.
Let me know if this helps.
Jer
Jan 17, 2010 | ViewSonic VG150B 15" LCD Monitor
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Acer X193w-- input not supported..
This is likely a screen resolution issue.
That monitor has a native resolution of 1440x900 (I used to have one). If the game is feeding the monitor too high a resolution, the monitor can't display it and.....input not supported. So, if the game has a configuration option (without going into the game itself) set the resolution to 800x600 and try to play. If it works, bump up the resolution until it looks acceptable.
Hope this helps!
Aug 21, 2009 | Acer AL1916W 19" LCD Monitor
Input not Supported
Run in safe mode and try to change the screen resolution to 800x600 and reset your machine.
Oct 27, 2008 | Acer V193w LCD Monitor
The screen will not come up but gave this message 'No input signal, go to power save
To isolate the problem, you need a friend with another computer since right now, we don't really know if the video section (or card) of the PC is at fault or the monitor.
You need to swap displays with someone so you can be certain what is actually not working.
The monitor is obviously capable of scanning inputs for a signal and not finding one.
Oct 26, 2008 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1912B 19" LCD Monitor Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
