Question about Dynex DX-WOM20 Mouse
Pairing WOM20 with Computer
My computer already has bluetooth, so I don't want to plug in the little USB thingy. Is there a way to put the DX-WOM20 into discover mode so I can pair it with my computer bluetooth? Thanks, Steve
    President:
  • 2,961 Answers
I think you may be getting wireless confused with bluetooth. Your mouse is wireless and it needs the wireless sender unit connected to a usb port, but this is not bluetooth, it picks up the wireless signal from the sender to work. You will also need to install any software that you got with the mouse (if any), as you will need to set up the button and click functions, unless it just uses the normal pointing device driver in windows.
Posted on Apr 25, 2007
SOURCE:
Tip
How to make a bluetooth headset pair with your phone or computer
1. All bluetooth headsets can be discovered by other bluetooth enabled devices (e.g. phone, computer) whenever they are in pairing mode.<br /><br />2. You'll know that it is in pairing mode by paying attention to its indicator light, which will always show a different configuration from the usual stand-by mode. On some of them, it will be steadily lit, whilst on others will flash rapidly, often in more than one color.<br /><br />3. You must ensure your headset is turned off, prior to putting it in that mode.<br /><br />4. Most bluetooth headsets, mainly the ones which are turned on by pressing and holding a Multi-Function Button (MFB, also called answer/end button) for a couple of seconds, enter the pairing mode by pressing and holding the MFB for much longer than the time required for them to be turned on (usually 6 to 10 seconds). Release the button when you notice it is in already in pairing mode (see rule #2). Other headsets, usually the ones whose microphone is in a boom, enter the pairing mode just by opening the boom, provided that either they have never been paired to other devices before, or, otherwise, those devices have their bluetooth radios turned off. <br /><br />5. Once it is in pairing mode, make the bluetooth application, on the device you want to pair it with, search for new devices. After a little while, your headset should appear on the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or pass code) is requested, enter either '0000' (four zeros, which happens to be the most commonly code chosen by manufacturers), or '1234', or '8888'.<br /><br />6. If the pairing process is successful, your headset will enter the stand-by mode. There might be some type of indication that a bluetooth headset is attached, on the device just paired with it too.<br /><br />7. You headset will stay in pairing mode for a couple of minutes only. If it happens to leave that mode before you are able to finish the procedure, turn your headset off and start it all over again.<br /><br />Hope these tips can be useful to you.<br /><br />Regards,<br />Carlos
on Nov 12, 2010 | Cell Phones
Have a Samsung smart TV. Will connect a logitech wireless touch Keyboard K400r. Do I put the unifying USB stick into het USB range Extender and therafter both into a USB slott on det backside of the TV. I...
as far as i know these tvs work with bluetooth keyboards and do not need an aditional usb reciever plugging into the tv, as it uses its own built in bluetooth. see sytem menu for pairing devices.
Dec 07, 2013 | Logitech Computers & Internet
How to connect htc smart to computer for surfing internet
Using USB...
On the phone, goto Start, Programs, choose internet sharing. On the computer, make sure that activesync doesn't think it is connected, and plug in a mini-usb cable into the phone. After a moment, Windows should detect the new "network connection" and take over from there.
Using Bluetooth,
Open the bluetooth manager. Setup a partnership with the phone (pairing). Once done, goto properties for the partnership, and check "enable network capability' or similar. On the phone, goto Internet Connection Sharing, and switch from USB to Bluetooth. Note, you phone needs to be paired with the computer already.
Sep 22, 2010 | HTC Cell Phones
How do you connect a bluetooth device to your computer
If your PC doesnt have a bluetooth capability, you need to have a bluetooth dongle, this device is a USB plug and play,, in order for you to connect any bluetooth device to your PC.
Sep 18, 2009 | Gateway M305CRV Notebook
Will not move pointer
Power down your computer, plug in original mouse, boot up. After computer boots, unplug original, and plug in your current mouse. If this does not help, call geek squad!
Aug 13, 2009 | Dynex DX-WOM20 Mouse
Dynex mouse for notebooks
This mouse is USB and not bluetooth. It will not work with the bluetooth wireless standard. It will only work with USB and RF. So, re-insert the base unit to the USB jack and press the button on the base, then press the button on the mouse, and it should work again.
Mar 24, 2008 | Dynex DX-WOM20 Mouse
Flashing USB
The flashing light on the adapter that is plugged into the USB port is normal operation of this mouse. In order to hide the light, I put electrical tape over it. There is no way to turn it off, as the flashing light is an indication that it is receiving a signal from the mouse.
Dec 27, 2007 | Dynex DX-WOM20 Mouse
Mouse trouble
To fix this problem, first uninstall your mouse in your device manager. After this, use the mouse's install CD to reinstall the driver. If you do not have a CD, or it does not require a CD, windows may already have the driver pre loaded and can take care of it. If not, you can goto the mouse manufacturers web site and download the driver from there.
Dec 05, 2007 | Dynex DX-WOM20 Mouse
Dynex DX-WOM20 Mouse Logo
300 people viewed this question
Top Dynex Computers & Internet Experts
gggg
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
