Question about Sharp R-530ES Microwave Oven
Sharp R-530ES microwave oven stopped working
After hitting the START button, the light comes on and the timer counts down, but no other operation- no heat, no fan, etc.
  • ddahl001 Dec 29, 2008
    Not just a fix, but advice on how to keep the problem from occuring in the future. Your folks are the BEST!
  • Anonymous Mar 15, 2014
    sharp R-530ES-T has no heat
  • Sharp Master
  • 9,098 Answers
You have a bad secondary interlock (lower door switch) or its mount is damaged or out of alignment.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 28, 2008
  • timnoles Jan 03, 2011
    Is this something that would happen in the middle of cooking? My wife was heating up some food and had it going for about 1 minute. Half way through, it just stopped working. Now, when we try to start it, we are getting the description from above (After hitting the START button, the light comes on and the timer counts down, but no other operation- no heat, no fan, etc.)
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Viking model VMOS200 after i put in cooking time and hit start, count down bignes and lights comes on but no running sound and no heat inside.
The Viking VMOS200 is a rebranded Sharp R-530ES. The R-530ES service manual is online here.
You almost certainly have a failed bottom door switch, or that switch's mount is damaged.
See the service manual and this file:
Jan 22, 2011 | Viking Microwave Ovens
Microwave timer works, light works, but heating mechanism will not engage-- no "sound" or "heating" when I hit start (although the timer mechanism sets & counts down, even when...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
Nov 06, 2010 | Hotpoint RVM1535MMSA Microwave Oven
Start microwave clockon sharp carousel oven
Not sure what the question is.. But if it is how to start the clock in a COUNT DOWN mode, then:
2. Program in the length of time you want to use, before alarm comes on
3. Hit start button.
Unit will beep at the end the count down.
Dec 10, 2009 | Panasonic Microwave Ovens
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Sharp R-530ES Microwave Oven Logo
436 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
