Question about Genius G-Pen F610 (31100050100)
G-Pen F610 blind spot (pen won't move over particular section)
I've recently bought a Genius G-pen F610, and installed it along with the recommended "macrokey manager" drivers in the included CD. All worked well, until i found out there is a fairly large vertical "blind spot" right in the middle of the screen and drawing board . (blind spot meaning that the pen icon would simply skip from one side of the affected area to another without being able to stop in the said place.)
This problem would obviously be a large setback when and if you're trying your art skills on an art program like photoshop or coreldraw...
Any assistance would be greatly appreciated
P.S: i use Vista home premium.. hope this helps
  • 2 more comments
  • Anonymous Feb 22, 2009
    I have the same problem. Sigh. One long vertical blind spot. The tablet works well on my PC, but not on my Mac.
  • Anonymous Mar 17, 2009
    I had been using my tablet for months now without problems and now it suddenly started skipping...no idea why.
  • kattyska Mar 17, 2009
    Same problem, but 2 horizontal spots... :( Not working on PC
  • Frank Walker Apr 22, 2009
    I use the F610 with "The Gimp". The pen will move the cursor but the paint tools won't function. They work fine using the mouse.
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
Posted on Mar 05, 2010
  • 1 more comment
  • d13r_an6r1ff May 15, 2011
    i have the same problem with the blind spot, vertical one, its near 60% of the tablet area from left to right and goes all the way from the top to the bottom
    i tryed evrything listed here, put the sheet of paper, changed the battery and downloaded the latest drivers... nothing helped
  • Semen Semenych
    Semen Semenych Oct 02, 2011
    How i can disassemble it?
    Problem Solver:
  • 6 Answers
Try downloading the latest driver from genius.com under products  go to tablets..then downloads.. you will find several drivers ..download the appropriate driver and it will work
all the best
Posted on May 09, 2009
Dead zone in my F610
i think its been dropped and this dead zone has damage to the screen or the connections so its a waste of time even trying to get it to work
Dec 02, 2011 | Genius G-Pen F610 (31100050100)
Replacement Pen for G-Pen F610 isn't working very well.
nomally happens the 1st time you use.
log off and back on again.
otherwise reset ... it should work next time you boot up.
Jul 21, 2010 | Genius G-Pen F610 (31100050100)
G-Pen Genius 450 doesnt work in cs4,xp
I have two cricut machines that the start button will not turn the machine on. What can I do?
Apr 04, 2010 | Genius G-Pen F610 (31100050100)
Laptop wont boot up after installing Genius F610
you need to run a nifty little program called Spinrite on your laptop. You can download it via BitTorrent HERE
you will need to use a program to burn the ISO image onto disk and make it bootable. I use PowerISO . It is very easy and straight forward. You can download it HERE (use the name: Dr.Upload
serial: SKSIP-7AIX1-8YWEZ-U197K-T88IE ) to remove restrictions.
Open the iso file using PowerISO. Now we have to make it a bootable disk image. Spinrite comes with FREEDOS instaled, but most laptops don't like using it.
Follow directions here on making a bootable image.
after burning your disk boot your system up with the cd. when you get to a prompt , ie C:\\ you will need to change it to your default cd drive mine is E:
after changing the drive letter type SPINRITE
the program will start - follow onscreen directions and change scan level to 5. after program finishes reboot after removing disk.
Oct 17, 2009 | Genius G-Pen F610 (31100050100)
Drivers don't install on macs OS10.5.7
Please check if your driver is supports the Mac OS then if it is not supported by your current system please find or download driver that supports the MAC OS. You can search using www.google.com.
Thanks
Jul 31, 2009 | Genius G-Pen F610 (31100050100)
G-Pen 610 install disc won't install tablet on MacBook Pro 2.2
hi there... Good news.. problem solved.. i was facing the same problem like thousands of others. not able to install the tablet f610 on to my macbook pro.
the solution turned out to be simple....
i went to the genius site.. go to products... tablets.. and under there somwhere u will find dowloads link... just download the  driver that you need.. ..
it will work.
best of luck
peter dsouza
Mar 29, 2009 | Genius G-Pen F610 (31100050100)
G-PEN F610 on iMac
When I installed the software, it never got to the "Software successfully installed" screen, but kept going through the installlation phase. As I looked in the manual, I saw that the last message one should get is "Restart your computer." I do not have CS3, butin the programs I have used I have not had any trouble with the pen. HTH
Barry
Feb 25, 2009 | Genius G-Pen F610 (31100050100)
Problem with g-pen 610
it will work.
best of luck
peter dsouza
Feb 21, 2009 | Genius G-Pen F610 (31100050100)
G-Pen F610 - Cursor is jumping to the left
You should try to replace the tip of the pen, that's how I solved it.
Jan 03, 2009 | Genius G-Pen F610 (31100050100)
G-Pen F610 versus Photoshop 7
I believe I understand what you are referring to. I can reproduce this same effect in Photoshop 6. The settings for tweaking this and other options like opacity is under the "BRUSH DYNAMICS" button for the particular brush. The default seems to have SIZE set to be managed by the STYLUS pressure. If this is changed to OFF, the size will remain constant, and you can use stylus pressure to change another dynamic. Hope this is of some help.
Dec 08, 2008 | Genius G-Pen F610 (31100050100)
Open Questions:
See all Genius G-Pen F610 (31100050100) Questions
Genius G-Pen F610 (31100050100) Logo
1,285 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
