Question about Amptron AMV 17V5 17" LCD Flat Panel Display 500:1Analog 15-pin D-Sub, Digital 24-pin DVI-D Silver with black... Monitor
LG 710s monitor problem screen turns green
Screen stays green and rarely returns to normal view
also problems with switching on screen takes three or four attempts to turn it on amv 17V5 flatscreen monitor wwhen pluged via vga, when i turn it on it shows a perfect coloring on screen but has the blue menu box in middle saying it is doing some kind of auto setting then it turns green haze on whole screen. turn power off, then on, does same : first perfect picture for 5 seconds then back to green hue. tried all color settings in menu: not it.replaced vga cord: not it.plugged to another computer(i have 3 ive tried): not it: other monitor works perf on same computers. this monitor has same problem on all computers.
  • Anonymous Feb 27, 2009
    Same problem..Screen starts - picture looks good then it has a blue tint to the screen that will not go away with anu adjustment. Model AMV A170E1. Please help.
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Posted on Apr 19, 2009
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Lg e700sh monitor out of shape i need the settings of original shape
try factory settings
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
Jun 14, 2011 | LG Flatron F700B 17" CRT Monitor
Lg2234s monitor goes of blinking...cant turn monitor off (blue light remains off) then monitor turns on ..screen pic returns but is totally green, the OSD becomes garbled, if set to return to default then...
emale36, Could be problem with the "switch-mode-power-supply" inside the unit. If dc voltage rail is noisey or marginally on the low side of rated specification then strange things will start to occur on screen. Contact LG (Lucky-Goldstar) if unit is covered by warranty. The unit will need to be evaluated by technician. Visit YOUTUBE to see video clips of monitore being repaired by their owners. Read more of my profile responses to other LCD owners. 12fixlouie
Dec 06, 2009 | Computers & Internet
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Nov 01, 2009 | LG Computers & Internet
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Green screen and attempting to switch monitor on
Click the Menu and try to degauss the monitor . Do u have any speakers kept near the monitor do keep away from the monitor,
Dec 16, 2008 | LG Studioworks 700S 17" CRT Monitor
How do i identify the wires of the lg 710s?
Vertical signal wire is yellow colour wire
Horizontal signal wire is White colour wire
Nov 22, 2008 | LG Studioworks 700S 17" CRT Monitor
LG 710S MONITOR
i suggest buying a new fan for it,it seems like its over heating.
Jul 26, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
482 people viewed this question
Top Amptron Computers & Internet Experts
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
