Question about Nintendo Wii Console
Controller problem al four light keep blinking on my controllerhow do i get it to work?
Open the tiny door on the front of the Wii next to the disc slot, there is a red button that says "sync". Press and hold that button for about 15 seconds and then the syncs should clear from the Wii. Then open the back of the Wii remote. There should be a small red button. Click the red sync button on the Wii and then click the red button on the Wii remote. The remote should connect to the Wii.
Posted on Dec 28, 2008
This normally happens when the battery,s in your Wii remote are low. Try a new (fresh) set of battery's. The alkaline type works best!!
Al 1217 error code H3
Heat roller abnormally high
temperature
Check the heater lamp blinking
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
MCU PWB.
Clear the trouble with SIM 14.
May 07, 2014 | Sharp AL-1217 Copier
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
Xbox wireless controller lights keeps blinking but
If the ring of light keeps blinking, it means that the remote controller was not connected to a receiver which is the XBox 360 console. Try to press the connect button on the console and the wireless controller to sync them together.
Apr 27, 2010 | Microsoft Xbox 360 Controller
Controller stopped working
turn your ps3 off wait till controller is off then plug it in with its cable and turn everything back on then press the ps button
Aug 14, 2009 | Sony Playstation 3 (PS3) Console
Parking brake light keeps blinking, 4 blink code?
make sure emergency brake pedal is pulled all the way up
May 06, 2009 | 1992 GMC Sonoma
Controller NOT Working Properly
I just came home to find this same problem. Four blinking lights on the wireless controller and the inability to sync the controller with my 360. On a whim I took out my controller's battery and then reinserted it after a few seconds. Voila! Problem solved. Controller works normally again!
Jan 22, 2009 | Microsoft Xbox 360 Controller
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Dec 24, 2008 | Sharp AL 1631 Copier
AL-1642CS
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Jul 23, 2008 | Sharp AL-1641CS Laser Digital Copier
The washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nintendo Wii Console Logo
56 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
