Question about Tomtom ONE 3rd Edition GPS
Cannot switch from pm to am
Re-set time
  • 54 Answers
From the Main Menu, click Change preferences
there is a clock icon in this menu set
Tap this button to select the type of clock that is shown and set the time
Posted on Dec 28, 2008
My Drayton lp522 clock is out by 12 hrs instead of 21.21 it reads 2.20am
Move the setting past 2.20 am so it switches to pm and set it for the pm time you want. You may have to operate a 12 hr/24 hr switch to get it right.
Nov 13, 2016 | Home
How do I get the remote set to AM/PM from 24hour military time?
There will either be a switch, or a button combination, if this is possible.
Feb 11, 2015 | Audio Players & Recorders
I want 38424 to turn on a lamp at 8 PM and turn off at 10:05 PM - Do I set it on "Timer" or "ON"
You want to set the clock after charging the device. Takes a short time. Set the time by pressing TIME and then HOUR/MIN for the current time. Now you can set the timer.
Press the "ON" and set the time you want the device to turn on.
Press the OFF button and set the time to the time you want the device to turn off.
Put the switch on the top to the TIMER position and lug into the wall socket and then the device into the timer.
Should be good to go.
Apr 13, 2014 | Stanley 38424 TimerMax Digislim Daily...
My bose wave radio 1 somehow switched to military time. There is no clock set button?
Not explicily, but on page 18 of the manual (Bose.com) clock setting is explained...
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Sep 08, 2011 | Bose Wave Radio
My bose just started using military time in place of the P.M. how can I get this back to using normal time?
It's in the manual...
Jul 05, 2011 | Bose Wave Radio
Please tell me in E-Z words how to set the clock and calendar on the Canon MP11DX calculator? Manual instructions, which I cannot locate anyway, are absolutely unclear. Please HELP!
To set the calender: Press the Calender/Time button. Press and hold the Time Set button for 3 seconds; the first digit of the date will start blinking. Then type in the date as two digit number for the month and date and a 4 digit number for the year. Add a zero in front of the month or day if under 10. Then press Time Set again. Press the CE/C button to return to the Calculation mode
(hold for 3 seconds)
Thus for today [Cal/Time] [Time Set] 0 9 1 5 2 0 1 0 [Time Set] [CE/C]
For December 1, 2010 [Cal/Time] [Time Set] 1 2 0 1 2 0 1 0 [Time Set] [CE/C]
To set the Time from the Calculator mode, you press the Calender/Time button twice before pressing and holding the Time Set button for 3 seconds; again the first digit of the current time will blink. Then type in the time as a 4 digit number followed by the AM/PM button to switch from AM to PM or PM to AM. Then press the Time Set button again and then the CE/C button to return to the calculator mode. You will see an A (AM) or P (PM) to the right of the time as you set it.
So for 5:06 PM you type
[Cal/Time] [Cal/Time] [Time Set] 0 5 0 6 [AM/PM] [Time Set] [CE/C]
I hope this helps. You can find the manual here: http://www.usa.canon.com/cusa/consumer/products/calculators/printing_calculators/mp11dx#BrochuresAndManuals as a pdf.
(I'm using Cal/Time for the button that has an icon that looks like a 1 month calender on the left and a clock on the left.)
Sep 15, 2010 | Office Equipment & Supplies
It does not switch on.
Does it switch on if you press the button really hard? I've seen some with the underside of the rubber plunger not cut squarely, making for a poor contact with the switch on the circuit board. On some I've replaced the entire rubber cap (from wrecked units, not available as a spare part though) or very carefully built p the tip of the plunger with 2 part epoxy glue that sets hard, like Araldite. If still in warranty, contact Garmin of course.
Sep 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Setting time & alarm on Sharp Chronograph wristwatch.
Instructions for Sharp Alarm Chrono (Digital)
Push "Mode" button until the mode is shown that you want to reset, do this even if the mode you want to reset is all ready showing.
Push "Reset", continue pushes until the desired Parameter (Minute, Hour, or Second) is flashing.
Use "Start" button to advance the digits to the desired setting.
Push "Mode" Button to finish.
Jan 12, 2008 | Watches
Setting the Alarm
After you set the time on your alarm, if the icon out to the side of it is am & you want pm, press the - button on the very top left hand corner & it will switch to pm. Vice Versa if the icon out to the side is pm & you want am
Jan 11, 2008 | Pantech C120 Cellular Phone
Tomtom ONE 3rd Edition GPS Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
