Question about PNY Technologies GeForce 6200 128MB AGP Graphic Card
I have the pny usb flash drive and it is write protected some kind of way. Is there anyway to remove this? I have all of my files and cannot do anything with them.
  • 3 Answers
It wasn't made compatible with vista and pny has no solution.
hold magnets next to the drive (I used fridge magnets)
then plug back in to vista pc
download this: http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
it should format quickly, if not done in a minute disconnect device, wipe with magnet again, plug in to usb, restart pc, run the formatter you downloaded, then go to device on computer and select format. should take a minute but it will work.
Posted on Mar 04, 2009
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
Unable to save files
this flash is write protected by a pass word
Aug 04, 2014 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How do you stop a pny 4gb from being write protected
A flash drive should operate just like any other drive. There is not write protect switch on it like an sd card. But, if the permissions have been set to be write protected on a given file or folder on the flash drive, then one can remove it through the control panel.
Or remove and replace the flash drive and make sure it has the latest driver running it.
Good luck on this operation.
Oct 23, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
Aug 30, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Pny micro sd won't copy files
has the write protect been moved
Jun 26, 2009 | PNY 2GB microSD Memory Card
I cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How do i remove the write protection on pny 8GB usb flash drive
Here is the answer from PNY.
http://www2.pny.com/support/support_single_faq_viewer.aspx?ArticleID=1415&RootSectionID=1057
Be warned, this is a low level format tool from them. What ever is on your flash drive will be erased.
I went exploring on these drives and found that when they start acting like they are write protected, it means that the drive corrupted. The low level format tool, will completely reformat that drive, and hopefully correct the problem.
They say it happens (usually) if you removed the drive from a computer, without using the safe eject USB function.
If this is a new flash drive, take it back to where you got it, and ask for a replacement.
Sep 08, 2008 | Computers & Internet
Install a disk in drive F?
Download this file from PNY to reformat your Flash Drive. It should work after that. Get the file here:
http://www2.pny.com/support/media//Files/06c3418a-bd4a-4a67-a7b7-f4415a58338a/Pre-test_v1.zip
Aug 22, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Computers & Internet Logo
73 people viewed this question
Top PNY Computers & Internet Experts
David
David
Alun Cox
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
