Question about Sony CDP-XE570 CD Player
Disk tray wont open
Cannot eject disk from player.
  • 85 Answers
Either loading belt for mech has gone meaning not unloading for door eject,or door belt has gone
Posted on Jan 08, 2009
Disk drive door wont open. LED light comes on an hums, but tray wont eject to open. Where is manual eject hole located?
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
The CD/ DVD/ Blueray player tray keeps opening and closing!
First make sure the "Eject" button has not stuck while pushed-in. Clean the Tray window/opening and the inside of the front part of the tray. Then try to push the tray in a little bit when closed and drag it out while open! By the time dust gathers on the greasy tray rails resulting it not to open and close to the full extent. If it helps but the problem comes back, then you should open the box and clean the rails more thoroughly. Have a look at the switch that senses the tray state (open/closed) too. OBS! That is not the same as the "Eject" button! Switch placement is device model deppendant but it is usually placed on the stationary part of the disc-player unit under the front end of the tray in the middle!
Some units do eject a disk they don't recognize. That a player can't read a disk could be a result of incompatibility, dusty optical lens or faulty/old laser. You may clean the lens by using a "Cleaning disk" or blowing with an air spray(or a straw with your mouth) through the opening of the tray.
Good luck
Please rate positively if helpful, thanks!
on May 06, 2010 | Televison & Video
Dvd burner wont eject
Open out a paper clip and insert it in the little eject hole on plastic tray cover and push gently until it ejects.
Jan 31, 2012 | Lite On Computers & Internet
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Aug 31, 2010 | Sony RCD-W1 2-Disc CD Recorder
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Disc tray wont open on xbox 360 hd dvd player
their is a lil hole on the front stick a pin in their and push, its the manual eject, and then pull the tray open, it should play your disks, but obv its annoying but it soulds like the mechanisms, and i dont think microsoft do repair on the hd dvd drive.
Feb 22, 2009 | Microsoft HD-DVD Player for Xbox 360
The tray won't open. There is a disk in the tray and I was able to play it back. But, when I tried to eject the disk, the tray woudn't open.
something like this is a physical problem. you should contact the manufacturer to see if there is a manual eject button and if not you will have to take it apart to get the disk.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
DVD Tray will not open
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Sony CDP-XE570 CD Player Logo
234 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
