Question about Kenmore Elite 45986 Front Load Washer
F11 CODE Kenmore 4T code f11 with 11 minutes left on the cycle. 90% of the time you can pause/cancel then start ,but you have to jar the unit to get it to go and may have to do this more than one time.
  • fuman1972 Dec 29, 2008
    where or how do i get to the wire harness
  • Anonymous Jan 09, 2009
    f11 code is prompting on my machine i tried to reset it by turning the circuit breaker off and on. When i called sears that is what they said.  Wednesday the tech is coming.  But my laundry is crazy and ill probably go to the laundromat.
  • 640 Answers
You have bad communication ,,between the control board and themotor control board..,,check for a lose harness at booth ends
Posted on Dec 28, 2008
I have an F11 code
Washer will suddenly stop with 1 minute left on cycle and shows the F11 error code...at times it may show the FdL code. The washer will then not finish no matter what I do. If I unplug the unit from the outlet that does not guarantee that when I plug it back in it will start up. Fifty percent of the time it still shows the F11 error. It can take hours to finally get the washer to cancel out so I can take the laundry out that has not been spun out.
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
The diagnosis of this failure usually requires a technician. If you are able to unplug the washer and safely access the central control board and motor control board, you can check for a loose wire harness connection.
Jan 24, 2011 | Kenmore Elite 45986 Front Load Washer
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE 4T has just started to stop with a code F11 , can you please explain. I have tried to switch cycles but that does not help
Thought this info might help.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Feel free to ask anything else.
Jan 19, 2011 | Kenmore Washing Machines
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Error Code for Kenmore HE3
The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
107 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
