Club car golf cart has clicking sound in rear
Clicking comes and goes usually at slower speeds. It is a '96 48volt that was rebuilt in '01
  • dcannow Dec 31, 2008
    This is a 1996 Club Car golf cart
  • Anonymous Mar 25, 2014
    When turning the car on a clicking sound comes from the dashboard. Only lasts a few seconds
    Master:
  • 416 Answers
It sound like brake shoe pulsation. Most probably you need to check rear brakes.
Another reason I just assuming since I dont have the car model and Brand.
Also it might be that if you can here this noise 20 seconds after you start driving, and if the resistor coil got very hot, that the solenoid might be bad. You need to check it too and if the solenoid is too hot to touch it can be bad. In this case cart really will loose a lot of power in both forward and reverse.
If you dont have that it might be brakes.
Let me know how it will go
Good Luck
Posted on Dec 28, 2008
What could be causing my golf cart to lose power? In the morning, it barely goes up the hills. It seems to run normally at night, but when I hit the gas pedal the lights go completely out.
Have the battery checked. Especially make sure they do a shunt regulator test on the cells. Sounds light a shorted cell in the battery.
Feb 10, 2018 | Cars & Trucks
When I coast I get a rapid clicking noise that slows as the cart slows. Cannot figure out where it's coming from. Sounds like a rear wheel
There is some confusion regarding this topic, which appears to be about a go-cart but listed as a problem about a 600 Amp programmable controller.
If your question is about a go-cart, then that clicking noise is likely to be normal. If the cart does not have a proper rear drive axle with a differential (crown wheel and pinion type) then one or both of the rear wheels will have a ratchet or sprag clutch. This is necessary because in a turn the wheel on the outside of the turn has to travel further and faster than the wheel on the inside. If the two wheels were going the same speed in a turn the tyres would skid. The Ratchet mechanism allows for one wheel to go slower than the other and operates like a rear sprocket on a bicycle.
Rgs. Bob
Feb 17, 2016 | EZGO 1995-99 DCX600 Controller 600 Amp...
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Find the year serial nimber A9649-548612 club car golf cart was manufactured
Since 1981 Club Car Golf Carts have positioned their serial numbers just under the glove box on the passengers side of the vehicle. The first two numbers (not letters) indicate the last two digits of the year of manufacture.
On Club Car Golf Carts prior to 1981, you can find the serial number by raising the seat and locating the aluminum, I-beam frame section closest to the batteries on the driver's side of the car. If the serial number plate has been removed, you can confirm it is a 1975-1980 model if it has two brake pedals and one accelerator pedal.
Oct 20, 2014 | Golf
When I start my club car it just makes a clicking sound
This is the most helpful group of cart enthusiasts you can find. I have gone from not knowing anything about carts to a decent tech. These guys know the ends and ours of every cart out there. You need to give more details about your cart so that I can begin diagnosing.
Aug 26, 2014 | Golf
Club car golf cart lights
Wiring, fuse and switch. Check for voltage at switch first, if none, check for a fuse in the circuit. I would suspect a fuse or faulty switch first.
Aug 20, 2014 | Golf
48v club car 2004.speed issue
the module on the end of the motor should do the trick.
Nov 06, 2013 | Dual Pro 48V 18Ah Club Car Golf Cart...
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Club car golf cart will only travel 3 ft. then cuts off.
See if the motor is bad. If the motor is getting really old the bearings in it may be getting to where they do not turn so easily anymore. On some electric golf carts there is a pressure switch under the seat that if you are not sitting in the cart it will stop the motor for safety reasons. If this switch goes bad then the cart does not know if you are sitting there or not. We used to test these switches by jumping the wires of the switch together to fool the cart into thinking that we were always sitting on the thing. It is a good way to test the switch but not a great way to keep it that way, that switch is there for a reason. If it is bad then get a replacement.
*NOTE: Not all carts have this switch, check with the manufacturer.
Nov 20, 2008 | Golf
Computers & Internet Logo
528 people viewed this question
David Payne
David Payne
