Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Thermostat Will NOT Turn OFF
By leonard_john on Dec 28, 2008
System continues to run even after it has reached targeted temp. It is like the Automatic button doesn't work. I have to turn the thermostat to the off postion, to turn it off. But when it comes back on later, it has the same problem.
Solution #1
posted on Dec 28, 2008
Not Rated)
Smithbrother
Rank: Wiz
Rating: 82%, 1399 votes
Most of these have a flag switch which starts then when the duct air goes through. If that fan switch is stuck it wil not turn off.
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
i have a he260 humidifier and the water does not stop running
Answer
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem... (More)
Answer
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on... (More)
Answer
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and... (More)
Answer
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to... (More)
Describe your Humidifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Humidifier Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
