Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Need part # on itc222 chassis
Have RCA model D52W14YX1 ,chassis ITC 222 . My problem like everyone else is 3 blinks when powered up , trouble code 19 . ALREADY REPLACED THE THREE MOST COMMON CAPS ! The part I have in question is cl 031 , burnt hole in board . Is this a resistor, capacitor or what? I can not find one of these at any of my local shops . It reads .0087uf 2000vdc. Any help would be much appreciated. Thanks.
  • Kelvin Boone Dec 30, 2008
    I got the RCA part # from my local dealer , they have some on backorder , been waiting on them for over a month now . I already tried radio shack , they dont have them . I will try the other place and see what i can find .THANKS
  • Measuray Franklin
    Measuray Franklin Aug 28, 2013
    .0087uf poly 2000v 5% is no longer available. It has been replaced by 103 10n 01uf 10000pf 2500v 383 mmkp L0814 AC and pulse metallized polypropylene film capacitor.
  • RCA Master
  • 5,138 Answers
High voltage Capacitor ,Call Radio Shack see if they have any or Call Electronix 1-800-223-3205.
Posted on Dec 30, 2008
The model indicated does NOT use a chip for convergence output; the convergence circuit is divided across three circuit boards.
Does the convergence option appear in the menu or NOT?
Dec 06, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
How do you release the board with the flyback on it? I've released all of the connections and opened all of the plastic clips but can not slide it out.
There are a series of plastic fingers that secure the edges of the circuit board into the plastic chassis frame. There are also two plastic arms that extend up through the defection board which have to get depressed and then the board is lifted up and out of the plastic frame. This only applies to the ITC 222 and ITC 222A chassis televisions.
Jan 07, 2011 | RCA Televison & Video
I cant find where to go to find the convergence option.. the manuel say's its under setup but on my tv thats not an option as it states in the pic can anyone tell me how to get in to convergence threw my...
That's a common problem with that model the auto convergence option would disappear from the setup menu. But it's a very easy and inexpensive repair that you can do yourself. You can get the RCA repair kit called the ITC 222 and ITC 222 A chassis convergence option missing repair kit. The kit contains the FL 231, DL 231, CL 030 and also has repair instructions on CD. Is $25 from listed under their RCA repair kit category.
My d52w20b rca tv will not turn on and if you hold down the power buton down the led flashes a code 19
All the ITC222 series will blink 19 if they have a no start situation regardless of the problem, Since the set wont power up the Main eprm cant communicate so it blinks 19 which means it cant identify the chassis. When you press the power to turn it on does the power light come on briefly then go out 3 times? Let me know and I will assist you with the problem. Also do you hear any sounds when the power is pressed?
Nov 27, 2009 | RCA D52W19 52" Rear Projection Television
Trouble turning tv on
sounds like bad capacitors on the RCA itc222 chassis.Need the model number of your set to help
Jul 21, 2009 | Televison & Video
Won't turn on-flashes 3 times.
Flyback and or CP150 are the most likely two components to cause that symptom. If you need more info let me know and also post the chassis number off the rear tag as that model used both ITC and ATC chassis numbers.
Mar 13, 2009 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
19, signal 19, 19, what is it trying to tell me?????
The only error code 19 for the ITC222 chassis listed from RCA/Thomson for 19 is invalid chassis detected. Which doesnt make sense unless you have replaced a PCB with a wrong part number.
Jul 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
299 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
