Question about Whirlpool Duet GHW9150P Front Load Washer
F02 problem The pump is pumping the water out( I see it moving through the pvc hose in bottom and into the stand pipe the problem is the pump wont shut off,goes to sud,pump shuts off for 4-5 min then kicks on again(theres no water to pump out) the goes to F02. I checked the clean out in bottom, it is clean. The impeller is turning and pumping water out. Its like its not getting a signal to turn off.
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*%^&^
Posted on Sep 29, 2010
Washing cycle wont finish, has trouble emptying
if it drains into a bucket it should drain into the stand pipe too,does it overflow out of the stand pipe (waste pipe) when draining?if so the pipe is blocked,also how high is the pipe?draining into a bucket might be less on the pump because gravity is helping drain if bucket is on floor,if the pipe is up high it might not be able to push it,there could be something in the drain hose that goes from the tub to the pump if it did drain no problems before,also when you stick the drain hose into the stand pipe if it's tight it might not have enough air getting into pipe to let it drain,fill the washer,put it on drain after you have some water in it,pull the drain hose out to the top of the stand pipe and let it drain,if it drains ok and water is going down pipe with no back up then it's an air problem,hard to say without being there,you're just gonna have to play detective,did you try to hold the bucket up higher than the washer so the water won't siphon out,if the bucket is up higher than the water level in the machine and it drains then you have a problem with the stand pipe or air gap problem.
Dec 04, 2017 | Zanussi ZWF 1221S
Stops in cycle and says f 02
F02 error is related to drain pump block.If the drain pump gets blocked or the drain hose is blocked the error comes up,this is indication of cleaning the drain pump and drain hose.If the drain pump and drain hose checked ok then its faulty drain pump,its not draining the water so the error f-02 is showing up. error F-02 is a slow drain problem. Remove the wide tapering pipe from the drum to the pump. Inside there is a non return ball valve. Clean this and see if that helps. Take the front bottom panel off and open the drain trap,and see if there is any thing got stuck up,like coins,nails,socks or any small cloth etc etc.--------------While removing the drain pump and drain hose for cleaning,please keep thick towel with you.As you disconnect the drain pump from its connection,lot of water will flow towards you,if your machine is filled with water.So keeping this towel with you will help to control this water flow towards you.This should help.Thanks.Helpmech.
Jan 19, 2011 | Washing Machines
Washer will not wash complete load. flashed f02, water not draining
F02 stands for long drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
you can press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
you might want to check..
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem most probably you will have to replace the pump
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The water will not drain and the spin cycle will not work.
Open bottom of machine and check the drain pump to make sure it's not clogged.
Mar 12, 2010 | Washing Machines
I have a Whirlpool Duet. I am getting an F02
You may need to disassemble all the hoses and inspect everything problem maybe a partial block? It can still drain but if it is slow and takes too long you will get the F02 error.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need help downsizing pool pump connection
Okay. I think I gotcha covered.
I have one mocked up here right in front of me.
Still going on the PVC pipe assumption...
- Install a PVC 1 1/2 " - 1" reducer on the new pump nipple.
- Install a short piece (nipple) of 1 1/2" PVC pipe in the reducer installed on the pump
- Install an 1 1/2" MIP adapter (PVC) on the 1 1/2 " nipple
- Screw the hose onto the threaded 1 1/2" MIP adapter.
There are several ways to do this -- the above is a good way.
Have you ever mated PVC piping/adapters with solvent? I can help you with the details of this if your unfamiliar with it...
Charlie
May 29, 2009 | Intex 1500 Gph Swimming Pool Filter Pump...
Bosch integrated dishwasher water pump wont go off
sounds like the drain pump stays on. take the kickplate off and check for water in the base. if no water then make that little red bar to the left of the watervalve in the base go up and down a few times. you could have a stuck microswitch on the pressure chamber
May 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
Duet
not a very normal condition you have here,lets try removing hte back cover, behind there on the lower left of the drum youll see a small black rubber hose leading from the top (pressure switch) to a resivour under/on side of tub, remove the hose and chck for clogs, blow though in both directions, i gues its possible that the hose and/or the spot where it connects to may be clogged with soap residue, preventing machine reading that the tub is actuallly empty.blowing through from bottom to the top yopu should here afaint "click" noise. thats the pressure switch activeting(normal) and blowin back down its possible and normal to hear bubbles blowing.
Dec 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
Jul 12, 2008 | Kenmore 46462 Front Load Washer
F02 code on duet/ht washer
We had this problem after our baby's socks started going missing in the wash cycle. We found them in two places: 1. Underneath the rubber gasket of the front-loading drum, and, 2. In the drain line, but not in the hose that comes out of the back of the machine. The manual and website make no mention of the three torx screws on the front, lower panel that can be removed, exposing a drain that can then be unscrewed (be prepared for A LOT of water to come out of here if you haven't been able to get it to drain). Inside here we found the culprit baby socks, removed them, ran a fan on the exposed electronics over night to dry them out, and put it back together. Problem solved. It's unbelievable that this information is not in the manual but had to be googled from sites like this. Hope this helps someone else and prevents an expensive service call. Maytag, you s u c k!
Apr 16, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
