Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer runs, no heat
The dryer works on first load, after that the dryer runs, but does not heat. Have checked the ocvious, vent tube, screen, even the igniter glows, but does not fire. Once colled own it wil fire again, obviously some kind of heat limiter or sensor, but I don't know?
Kenmore He3 gas dryer, model 923832100
    Sergeant:
  • 311 Answers
Hey mark we got this one done.if your ignitor is glowing and its not firing over 2 things flame sensor,but rarley.99 out of 100 will be the valve coils 2 black guys on top of the gas valve with wires going to them.you could use the cheapest brand you can find[ie..frigadire,ge,kenmore,amana.there all the same .on my truck i stocked frigadire because it was cheaper for me and then would make more profit yet charging same price as there brand,you can do it .God bless,tom
Posted on Jan 01, 2009
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer runs and spins but does not heat up -the clothes remain wet. Lint is not the issue . Iclean the lint trap every load. I also vacuumed out the coil vent ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 03, 2011 | Dryers
Will start, won't completely dry our clothes... Taking FOEVER!!!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 01, 2011 | Dryers
There is not much hot air in dryer so it takes a long time to dry one load
restriction in the vent tube or dryer itself: first remove vent tube run the dryer if it drys correctly vent tube, if not then take dryer apart and clean the lint from below lint screen to vent tube connection. Good Luck Tim
Jan 15, 2011 | Maytag Dryers
Dryer not drying clothes properly
Replace the vent tubing, sounds like something is stuck or it is crushed somewhere. So replace it for about 5 dollars and see if that works. It should since you disconnect the hose and it drys right away
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
MY DRYER RUNS BUT WE GET NO HEAT?
Try this first.
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Oct 06, 2008 | Dryers
Neptune MDG5500AW Gas Dryer
Friend,
ngfam1 At your service!
CHECK ALL these spots!
Try this first.
2. Then check if the outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this second and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
2 years that mine is off and it's all is fine.
You will be fine
Bless You ngafm1
Sep 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer repaire
Friend,
1. If the dryer is gas and old, the pilot could be out or if it is newer it could have a defective or worn out a igniter!
2. The lint filter is full and needs to be cleaned.Try this first
3. The outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out! Try checking this second! if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently! I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 30, 2008 | Dryers
Wont heat
Try this first.
Bless You huuum
Jul 25, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
122 people viewed this question
Sal De
fordexpert
Robert Rankin
