Question about Panasonic PT-AE2000U Projector
RS 232 control
I am trying to figure out how to control the PT-AE2000U VIA RS232 control.
Do I use ASCII or HEX ?
The manual lists RS232 commands.
The power on command is PON
Does this need to be converted somehow to be understood by the equipment?
..did you ever solve this? i am trying to write some code to do the same thing with no luck at all. and the manual does not seem to help much besides letting me know that I have to use 'PON' and pad it with a start bit and an end bit. i find nothing online as well.
Posted on Jun 28, 2010
RunCo VX1000c RS-232 communication codes
Hi Kevin,
The manual for the RuCo VX1000c is available at http://www.aboutprojectors.com/pdf/runco-vx-1000ci-manual.pdf
The RS232 codes and protocols are towards the back of the manual. According to the manual, the PFP connects to the projector using a CAT5 cable.
HTH.
Jan 02, 2013 | Office Equipment & Supplies
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Rs-232 set up codes for the sharp xg-c335x
you can fined rs232 commands on the CDROM that comes with the projector.
Nov 05, 2009 | Sharp Televison & Video
Rs 232 command Sony FWD32LX1R
Hello, i found the solution:
Screen off
^x8C^x00^x00^x02^x00^x8E
^x8C^x00^x00^x02^x01^x8F
Kind regards
Roger
Jan 05, 2009 | Sony FWD32LX1R Television
PC4 doesnt appear to recognize ANY IPL coding
1. Add Generic Printer to printer list.
2. Select Generic printer as Default printer
3. open the document and print.
Jul 14, 2008 | Intermec EasyCoder PC4 Label Printer
Rs 232 connector wiring
the problem is the Rs 232 connector is not all same,.the wire in the cable like my machine is different from usually printer does.
Jul 10, 2008 | PSC Duet RS232 (4310001-1000001021)...
Printronix5003H+ table mismatch
I'm sure you have fixed your printer by now... but reflash the printer.
Flash memory is contained in SIMMs (single in-line memory modules) located
on the controller board. Printer emulation and operating system software are
loaded into flash memory at the factory, but you will install software in some
situations:
• The customer buys the PGL or VGL graphics, Expansion-CT, or IPDS
option after the printer is installed
• The customer needs to upgrade printer software
• The customer needs different emulation software
• You have replaced the controller board
• You have added or replaced the flash memory SIMM
Emulation and operating system software are stored as a compressed file on
a 3.5 inch floppy diskette. This file is “executable.” You will expand it and copy
it into printer flash memory.
You can load software through the serial, parallel, or Ethernet port of the
printer.
1. If the printer has an Ethernet interface, refer to the PrintNet User’s Manual
for the download instructions. You are finished with this procedure. If you
are going to load memory through the serial or parallel port, continue with
this procedure.
2. Make a printout of all saved configurations. (Refer to the User’s Manual.)
(Installing new software erases all saved configurations. You will use the
printouts to restore printer configuration.)
3. Set the printer power switch to O (off).
4. If the printer is already connected to the serial or parallel port of a
computer capable of running an MS-DOS® based PKZIP® self-extracting
file, go to step 11. If not, go to step 5.
5. Unplug the AC power cord from the printer.
6. Disconnect all data input cables from the printer interfaces.
7. Connect a parallel data cable to the LPT1 port or a serial data cable to the
COM1 port of an IBM-compatible computer that is using the PC-DOS™ or
MS-DOS operating system.
NOTE: You can connect the cable to the LPT2 port if the LPT1 port is alreadyin use. The load commands are different if you use this port, as
described in the note after step 18.
8. Connect the data cable to the appropriate I/O port of the printer.
9. Plug the AC power cord into the printer.
10. Power on the computer.
11. Insert the emulation or upgrade diskette into diskette drive A (or B) of the
computer.
12. Make the diskette drive the active drive by typing the following at the DOS
prompt:
A:<return> (If the diskette is in drive B, type B:<return>)
13. Get the name of the compressed file on the diskette by listing the
contents of the diskette; at the DOS prompt type:
DIR<return>
The compressed file on the diskette takes the form FILENAME.EXE
Now write down the complete name of the file with the .EXE extension.
14. On the printer control panel, press and hold down the ON LINE + PAPER
ADVANCE keys. Without releasing the keys, power the printer on.
Continue holding the ON LINE and PAPER ADVANCE keys down for five
seconds, then release them.
NOTE: The port default is CENTRONICS; this is the standard load through
the parallel port. If you want to use the default, continue at step 18.
15. When you see “WAITING FOR PROGRAM DOWNLOAD” on the LCD,
press the < (NEXT) key. “SELECT DOWNLOAD PORT =
DATAPRODUCT” appears on the LCD.
16. Press < (NEXT) again to cycle through the download ports available in
the printer:
DATAPRODUCT (parallel)
CENTRONICS* (parallel) (default port)
RS232-9600 (RS-232 serial, 9600 baud)
RS232-19.2K (RS-232 serial, 19200 baud)
RS232-38.4K (RS-232 serial, 38400 baud)
RS232-115K (RS-232 serial, 115000 baud)
RS422-9600 (RS-422 serial, 9600 baud)
RS422-19.2 (RS-422 serial, 19200 baud)
RS422-38.4K (RS-422 serial, 38400 baud)
RS422-115K (RS-422 serial, 115000 baud)
17. When the printer download port you want to use is displayed on the LCD,
press ENTER. “WAITING DOWNLOAD / PORT = <your selection>
appears on the display.
18. At the DOS prompt on the computer type:
FILENAME.EXE -pb<return>
where FILENAME.EXE is the compressed file you noted in step 13. This
command decompresses the file on the diskette and copies it as a binary
file into the flash memory on the printer controller board.
NOTE: If you are loading the file using the LPT2 port on the computer, enter
the following DOS command:
FILENAME.EXE -pb 2 <Return>
The 9600 baud rate is the only selection older versions of DOS can
use. The baud rate information entered in the following DOS
commands must match the selection you made in step 16.
the load process and status. (LCD messages are listed in Table 2,
page 37.)
CAUTION Do not interrupt the downloading process once it has started.
Interrupting a download will damage the flash memory on the controller
board and PrintNet card ( if installed).
19. When the new program has successfully loaded into memory and the
printer has reset itself, set the printer power switch to O (off).
20. Unplug the AC power cord from the printer.
21. Remove the diskette from the computer and store it with the printer.
LineMatrix
www.sinca.biz
Toby
Jul 07, 2008 | Printronix Line Matrix P5215 Printer
Projector Serial Port Codes
Hi there
They might be the same if the Projectors are from the same series.
First figure out if the RS232 codes are in ASCII or HEX. You will most probably be using the HEX codes.
Best would be to contact the dealer you bought this unit from - they should by all means be able to help you out.
Apr 01, 2008 | Office Equipment & Supplies
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Oct 28, 2007 | HP (158800-001) for Compaq Presario 1246,...
Open Questions:
See all Panasonic PT-AE2000U Projector Questions
Panasonic PT-AE2000U Projector Logo
298 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
