Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony grand wega KDF-55wf655 TV goes into flashing green mode
The TV was working fine all morning. All of a sudden it kept cutting in and out (with a warm up flashing green light). At one point, the lamp light came on, but that has since passed. I only hope it's not the lamp - we just had it serviced and basically rebuilt last year. It took 3 weeks and way too much patience with sony. Any ideas on how to rule out the lamp?
  • 1 more comment
  • Anonymous Jan 11, 2009
    I have the same problem. The TV comes on for a few seconds then cuts off and the grren light flashes the process continues every 30 seconds.
    Have you found a solution?
    Thank You,
    Joe
  • stveide Jan 17, 2009
    My power light flashes 5 times, pauses then flashes 5 times over and over. When I hit the power button again, the TV comes on with video and sound then dies, then 30 seconds later it comes on then dies. Over and over.
  • Anonymous Feb 12, 2009
    Thank you
I was having the same problem. I am no expert, but what I read on-line is that it was likely the lamp needing replaced, that the lamp toward the end of its life will flicker and cause the TV to "reboot". I had no Red Lamp replacement light, so I wondered if that was really the problem. But, I bought a replacement lamp for $110 plus shipping, and replaced it last night - TV is working great now. I would try replacing the lamp on yours first yourself (if the lamp is older than 2 yrs), then if that does not work, contact a service person. Don't have a service person replace it, because I have heard many people say they paid $400 for a replacement lamp service, and I did it for under $140 with overnight shipping charge for the new lamp. My original lamp lasted 4 years, so I was lucky to not have this problem sooner.
Posted on Feb 27, 2009
Found out the my extended warranty is still active - have a service call in. Will update this solution when the "experts" finally return the call to schedule an appointment. Hope it doesn't take the usual four weeks to get the TV returned in working order. I will keep you posted.
Thanks for your quick reply.
Donna
Posted on Dec 29, 2008
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-55WF655 picture and sound are going on and off. The green light flashes when they are off and when they come back on the picture comes on first then the sound.
These are symptoms of weak lamp as lamp in tv is reaching to end of its working life and will be replaced to fix this issue.
Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Apr 18, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF 55WF655 rear Project tv Power/standby light flashing
This would be an error code indicating a problem.  You didn't mention if anything else was going on with the TV as in no picture, or no sound.  If the TV is operating just fine, there could be a bug in the software causing this.  If there is a problem, the best thing would be to contact Sony and relay that error message and go from there.
Mar 26, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Jan 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Flashing green light no picture
The bulb was loose, pulled it out, put it bakc in and tightened the screww. Works like a champ
Mar 06, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
199 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
