Question about RIM BlackBerry Pearl 8100
Blackberry rolling ball will not roll down
I have a blackberry world edition. It has worked fine for a year and all of a sudden, the ball will not allow me to scroll down, only up and sideways. Any suggestions on how to fix this?
  • 2 more comments
  • KAucapina Dec 28, 2008
    I have the same problem with my blackberry. After one year of working fine, the rolling ball will not roll down and I don't Know what to do. I was checking the manual but it did not help at all.
  • Anonymous Jan 01, 2009
    The roller ball doesn't work in my pearl either, I am so tired of not being able to use my very expensive phone because it won't work!
  • klbanfill Jan 01, 2009
    The roller ball in my phone does not work. The ball rolls but the cursor doesn't move. I have tried pressing hard and rolling it while it's off, I've tried canned air and nothing works.
    Also, I can't send or receive emails from my yahoo account even though I set it up in the email wizard which means I also don't get facebook notifications because the connection is missing somehow.
  • Anonymous Feb 17, 2009
    I have had my blackberry for 2 months now and have had nothing but problems with that stupid ball. I am taking it to verizon today to see what the problem is.
    Sergeant:
  • 367 Answers
Cleaning the track ball on blackberry phones. Remove the metal ring then the ball mechanism remember how you removed it because it needs to go in the same way. You can also try removing the battery from phone taking a qtip with alcohol the higher the percentage of alcohol the better. and wiping and rolling the ball around even without removing it from the phone. this usually helps unless the ball is extremely dirty. Below are step by step ins for removing the ball. just follow the link
Removing blackberry tracball (non BOLD)
Posted on Jan 02, 2009
Blackberry 9630 Trackball not working in the main menu
hold down alt key and swipe roll the ball. for emergency purpose. ferrah.com@gmail.com
Dec 10, 2011 | RIM BlackBerry? Tour 9630 Smartphone
My tracking ball has stopped working. Tried removing the battery while powered on, but it's still not working properly. Can move sideways but not up or down and can't retrieve messages.
All that is, is dirty. Just push it down a few times and try to roll it in a circle and dislodge what's stuck in it. Once you get it rolling free. Take a cotton swab, dip it in pure rubbing alcohol, not dripping, and rub it all over the ball, move the ball around and let it dry for like 3min. Your ball will be fixed and clean
Sep 16, 2011 | RIM BlackBerry Curve 8310 Smartphone
My roller ball does not roll down it goes all other direction but down
there is something stuck under the ball. take the phone and roll the ball on clean white paper facing dowing in all directions. I
Feb 10, 2010 | AT&T Blackberry Curve 8300 Smartphone
My blackberry scrollball is not working. It canonly go left to right and vice verssa but can not move up or down
Have you tried cleaning it? The best way I clean mine is using a q-tip, dabbing it in rubbing alcohol, be sure to squeeze the excess out of the q-tip, and roll the wet q-tip all around the ball. Make sure you roll the ball so that all of it gets the alcohol on it. You can use the other side of the q-tip (dry side) to dry the ball.
Hunnybunny11
Jan 24, 2010 | Cell Phones
Ball on blackberry wont navigate up or down
Hi. BlackBerry smartphone trackball fails to roll in a particular direction because, debris is lodged in the trackball.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in a desktop computer.
Using for certain period debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
I hope this information will be helpfull.
Nov 11, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
When I roll the ball to the left, the cursor doesn't go to the left?
change the trackball sensitivity
Steps :
1. Click Menu Key
2. Go to options, under that select Screen/Keyboard
3. scroll down you will get track ball settings
Horizontal sensitivity
Vertical sensitivity
increase the sensivity to 100 then you will be able to roll track ball,it will work fine....
Oct 30, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I can't scroll down with the rollerball
The balls on the blackberry's get clogged up with finger oil, skin, and all sorts of grime I think. But I fixed mine by shutting the phone down and then rubbing hard against the roll ball in each direction and pushing each time until the clicker under the roll ball clicked. You could also try alcohol.
Oct 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Ball wont roll left
Cause:
The sensitivity of the trackball/trackwheel might be less
Faulty Hardware
Resolution:
Increase the sensitivity by following procedure
Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100
if still not working contact service center
Jul 08, 2009 | RIM BlackBerry Pearl 8100
Blackberry rolling ball issues
Is the ball registering left right up and down and just not selecting? Sometimes the ball gets dirty. You can clean them most of the time. If its the actual select button, it sounds like it needs replacing. This repair runs 65.00 plus shipping. The actual button is a solder-on button so it requires more attention. Try http://www.pdasmart.com for your blackberry repair needs!
Apr 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
5,706 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
