Beeps i have the 60 inch rca ctc 195 series home theater that wont come on al it does is beep i dont now were to find the chassis number for you were do i find it so i can get this fixed. charlie_harris_2004@yahoo.com
  • charlie_harr Dec 29, 2008
    p60925bl
  • ladywinn
    ladywinn May 11, 2010
    you just told chassis # ctc195 whats the Model #? look on back of TV.
  • 5,138 Answers
OK Replace FBT #239111 Flyback transfomer and Hori output NTE2324 (((((((FBT 22.95 -- ACME 1-800-575-9833 1yr warranty on theres.
Posted on Dec 28, 2008
Rca rt2911 beeps
Try with an hdmi cable . I think
Mar 04, 2013 | RCA rt2911 1000-watt hdmir home theater...
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Where is the convergence power supply located on a RCA P52960?
TAKE A CLOSE LOOK AT THE LABEL ON THE BACK OF THE SET WITH THE MODEL NUMBER, IS IT MARKED PTK195?
THE PTK 195 uses a power supply mounted above the main boards and is about 10 inches wide and 4 inches deep.
It is very common on this model for one of the ten diodes to be shorted; confirm it is a 195 chassis and I will tell you how to locate the two diodes that fail. They supply voltage to the convergence circuit and I have seen dozens where one of them shorts.
Let me know what you find; is it a 195 chassis?
If this information has helped you rate this solution as I do this here for free, rate it "very helpful".
If it is a 195 chassis let me know and I will pinpoint the location of the two diodes and tell you how to check them.
REGARDS, SD TECH
Aug 10, 2010 | RCA P52960 52" Rear Projection Television
CTC 195 series
Horizontal output transistor is needing replacement for sure and quite possibly the flyback as well
Jun 29, 2008 | RCA P56950 56" Rear Projection Television
RCA 60 in. rear projection when I cut it on it cuts back off
I need the model # and the chassis no. ctc and numbers /letters that follows ect
May 05, 2008 | Televison & Video
Rca ctc195 big screen tv trouble
You are likely to have a high voltage transformer bad which is common problem for ctc 195 RCA If you look into the back of the tv it is the white square looking thing about 3 inches across by 3 inches with the large red wire coming from it and going back into the set. Must have original RCA part and must be unsoldered and solder in new one. Not to be done by the untrained. Average cost to come out and repair is $250 to $300. depending on the repairman (Note: the chassis is in a complete wooded chipcore box that will come out with quarter inch nutdriver and unplug two plugs at the top of the box The box or chassis can be taken to the repair shop leaving the screen at your home saving a service call. Hope this helps
Dec 30, 2007 | RCA P52937 52" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Rca p52927 chassis ptk 195 wont power up all of a sudden
ctc chassis with the 195 chassis were famous for flyback transformer shorting and taking out the horizontal output transistor also.
Oct 24, 2007 | RCA P52937 52" Rear Projection Television
RCA ctc 195 series
this tv most likely has a shorted horizontal transistor and transformer. Now that you have a heads up on the problem it's best to contact your local tv rep. John
Sep 13, 2007 | RCA P56950 56" Rear Projection Television
Rca ctc 195 series
Before anyone changes those setings you should write them down.
Apr 15, 2007 | RCA P56950 56" Rear Projection Television
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
