Question about Lexmark X1150 All-In-One InkJet Printer
Computer tells me that it cant communicate with printer,
Other computer works, checked all cables
  • nise7 Jan 04, 2009
    I have installed printer into a new computer but it tells me the computer can't communicate with the printer. Have checked the UBS ports, unplugged and plugged back in and restarted the computer, nothing changes.
  • Pat Batta
    Pat Batta May 11, 2010
    Did you installed Driver BEFORE plugging PRT?
Downloaded new driver uninstalled &reinstalled still does not work . the power button flashes off &on.
Any suggestions would help.
Posted on Dec 29, 2008
My Lexmark Z1420 Is not communicating with the P.C. Have checked everything and it tells me it cannot communicate with printer. The printer works with other P.C.
If its a Windows PC, you need to unplug the printer, Boot the computer in the Safe Mode, and remove the drivers (with the Device Manager). You might find duplicates. Remove them all.
Then reboot and install the drivers again, following the directions on the driver installer. Windows needs these extra steps.
Jan 26, 2015 | Lexmark Office Equipment & Supplies
Communication error epson 520
Check your cables are in the correct positions., Turn the printer off and reboot your computer. Check the computer and see if it " finds" the printer. On the PC, press "start" look for and click on "printers and or accessories" Your printer should be displayed there. Click on properties. If the PC cant find it, I would say the cable is damaged or disconnected or the software for your printer has been deleted or failed. You may have to reinstall the software again.
Aug 26, 2014 | Epson WorkForce Office Equipment &...
Lexmark X5495 printer cannot communicate with the printer, I can scan images from the same printer, but cant print. Tried to unplug the cables, restarted the systems, uninstalled and re-installed the...
If you can scan the USB port, it should be OK. If "copy" works correctly and you have recently installed drivers, try resetting your computer and selecting the printer as "default." Check if there is an impediment on the printer panel, blank cartridges or another error. The printer can scan but can not print if it has empty cartridges. Study the user manual on http://publications.lexmark.com/publications/pdfs/2007/5400-plus/v6592051_en.pdf
Nov 04, 2017 | Lexmark X5495 Printer
Printer cant communicate with computer - I have tried to download the x2650 driver twice and after installing it I try to print and get the error message "Printer cant communicate with computer" I also...
Connect the printer to a different computer, and see if it is auto-detected, or if the printer itself is "dead".
Try a different data-cable between the printer and the PC, to ensure that the data-cable is not the problem.
Oct 07, 2009 | Lexmark X2650 All-In-One InkJet Printer
Printer 924 dell cant communicate with computer
cannot comunicate means you have to reinstall the driver again, could be corrupted after the virus, also communication problem could be from the cable you use, check both.
Apr 17, 2009 | Office Equipment & Supplies
Problem communicating with the printer
Did you just install the software? if not then check your cables. If they are firmly attached thentry a different usb port on your computer. If that doesn't work then un-install the lexmark (not delete) and reinstall following directions. After Download make sure printer if off and usb cable is unplugged from the printer. Start the program and follow the diffections. But only connect when it tells you to do so.
Dec 29, 2008 | Lexmark X5150 All-In-One InkJet Printer
Not communicating with computer
check your cable which connect your printer to your computer.
replug again it.
also check u proper driver installed for printer.
u can download from here
http://www.brothersoft.com/hp-pavilion-5000-and-7000-series-s3-trio-download-111409.html
Oct 03, 2008 | Lexmark X2250 All-In-One InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
