Question about Citizen CBM 1000 thermal Printer
My printer wont print
My printer has a seriel conection but my computor only has usb.i have tried using a usb2.0 to rs232 cable but i still get nothing out of the printer.should it work with this cable or could there be a conflict of drivers.i would appreciate any help with this,thanks
  • Anonymous Aug 22, 2008
    my printer has a seriel conection but my computor only has usb.i have tried using a usb2.0 to rs232 cable but i still get nothing out of the printer.should it work with this cable or could there be a conflict of drivers.i would appreciate any help with this,thanks
The mfgr. and its distributors sell a usb interface card that can easily be changed by the end user. rec. P.R.I. 1.800.533.2297
Posted on Jul 27, 2007
Easycoder C4 Printer wont print
See if this can help:
epsfiles.intermec.com/eps.../1-960572-01%20UG%20EC%20C4.pdf
May 26, 2014 | Intermec Easycoder C4 Therm Label Printer...
My zebra 105 se wont print using RS232 serial cable
Make sure the serial dip switch settings match your com port on the computer. You need a null modem cable or adapter.
Mar 04, 2011 | Zebra 105Se Thermal Printer
My printer wont print out a letter i need. it says to check conections and make shure it is turned on but i tried it and it still wont work
You may have a problem with your communication connection.
1) Try plugging and unplugging your USB cord..
2) Go to "Control Panel/Printers".
3) Delete "Canon iP1800 series" printer.
4) Power ON printer, let computer detect printer.
If it will not detect and install the printer. There might be a problem with your USB cable.
Hope this helps.
Jan 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Can not reinstall printer
Try disconnecting the printer from the USB port and reinstalling the CD program. Don't connect the printer to the USB port till the program says to do so.
Hope this help. Bud
Jan 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
My computor is not able to locate the printer
First make sure that the usb cable and power cable is connected to your printer
Nov 03, 2008 | Lexmark X1240 All-In-One InkJet Printer
Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Mar 12, 2008 | Zebra Z4Mplus Label Printer
My printer wont work
Buy a USB to Serial adapter for your computer. Check http://www.usbgear.com/USB-Serial.html
Apr 26, 2007 | Citizen CBM 1000 thermal Printer
Citizen CBM 1000 thermal Printer Logo
222 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
