Question about RCA R52WH73 Projection Television
Bowed/Warped picture/convergence problem
I have a bowed/warped picture and the picture looks like it's in 3D, showing Red, Green, and Blue colors. I did some searching here on the FixYa site and found it's a small fuse that needs to be replaced for my convergence problem. The convergence option on the menu has disappeared as well.
I took the bottom panel off and didn't realize how many circuit boards these TV's have. I'm not sure what I'm looking for and I was curious if you could lead me in the right direction. I'm thinking about taking the top, back panel off as well to see if I can find a blown or burnt fuse. Like I said, I don't know what I'm looking for. I'm not touching a single thing until further instructions on what I need to do for this project. Any help would be greatly appreciated.
Thank You,
Chris Kelso
Username: Nerosfiddle
cdkelsotwo@hotmail.com
  • RCA Master
  • 5,138 Answers
There is 2/3 boards on bottom first board to left is the Deflection board next to it is the SSB board it has the tuners and video jacks on it. Deflection Board has 3 fuses right in a roll on right side of FBT Flyback Transfomer (FL231) it will be middle fuse 400ma they do not look like fuses they are small brown rectigular you can pull top off of them with needle nose plyers to check fuses on top.
Posted on Jan 04, 2009
The screen seems bowed or warped , and I can not get the colors to line up when adjusting the convergence.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get parts and repair instructions from www.TvRepairKits.com. You can also see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 25, 2011 | Philips Magnavox 9P6034C 60" Rear...
Bowed screen at top and bottom also red and blue out line shawod on every things that showing . could it be a burnt out builb?
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2011 | Samsung HCN473W 47" Rear Projection...
Phillips 51pp9303h/17 red and green double vision of writen words and bowed line of red green at bottom. some objects in show look real shiney. and double vision of others.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 29, 2011 | Philips 9P6031C 60" Rear Projection...
Bowed red green lines at top screen. picture looks like it in 3d.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 28, 2011 | RCA HD52W59 HDTV Projection Television
I have a sony center of tv is clear but top left corner has a redish bow and very bottom is bowed
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Sony KP-57WS500 57" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
My red color on the color convergence does not match the blue and green color
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-56WP74 56" Rear Projection...
Tripe image, blue, red and green color on image, not focus
Screen looks 3D
Aug 28, 2009 | Televison & Video
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
RCA R52WH73 Projection Television Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
