Question about Apex Digital GB51HD09 51" Rear Projection Television
No picture but have sound and powers on
I believe i need a new scan board assembly from somewhere.i have water corrosion on that board and that is the only one so if anyone has one of these tvs that would consider selling me the scan board assembly out of it or know wherer i can possibly purchase a replacement, please email me at jvolling1981@yahoo.com thank you Jeremy Model number gb51hd09 PLEASE HELP
    President:
  • 1,284 Answers
You probably have a leaking CRT (picture tube) as well. Don't overlook the issue before replacing the board otherwise you will burn a second one.
Posted on Apr 26, 2007
I have an LG RU-42PX11 plasma tv. A couple weeks ago we heard a pop and the picture went blank. I can still change channels via cable box and I have sound but no picture.
6871QCH034A PCB ASSEMBLY,DISPLAY CTRL ASSY 42V6 NEW MCM(1222) LVDS
202 6871QDH066A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV TOP ASSY
203 6871QDH067A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV BTM ASSY
204 6871QLH034A PCB ASSEMBLY,DISPLAY XRLT ASSY 42V6_XL(4LAYER)
205 6871QRH037A PCB ASSEMBLY,DISPLAY XRRT ASSY 42V6_XR(4LAYER)
206 6871QYH029A PCB ASSEMBLY,DISPLAY YSUS ASSY 42V6
207 6871QZH033A PCB ASSEMBLY,DISPLAY ZSUS ASSY 42V6
These are the part numbers for all the boards that deal with the display. Im leaning towards the sustains as well and you need to do both at the same time cause if one is bad and you replace just one, a bad one can fry the new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 20, 2017 | LG Televison & Video
Rca 46la45rq has backlight and power but no sound or picture replaced main and inverter boards
Was this the original problem before replacing the main board?
Maybe you have to set the new main board from maintenance menu. Sound and image comes from the main board, so i believe it has to be something about it...
good luck
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
Dishwasher powering off
Sounds like the control board alright, but often repairers witll just replace a board without identifying what caused the fault.
There could be a peripheral device that is causing the failure. I would replace the solenoid valve that allows the water to enter the machine and the control board. when the old board is removed it should be thouroughly checked for water marks or corrosion, all connecting cables to the control board should be checked for wear and corrosion and be recrimped if nessesary, when the new board is fitted its anchoring should be checked to make sure that it is very secure. lastly all ground/earth points should be checked.
Often removing the base of the dishwasher can help identify if there is a small leak, remember it onyl takes one drop of salt laden water to cause damage to these control boards.
Hope this helps :)
Oct 03, 2012 | AEG 23 in. Favorit 86070Vi Built-In...
I can not get the power to turn on. I believe it may have corrosion form leaving batteries insdie the flash.
Clean as much corrosion as you can from the contacts. If you've already done so then the corrosion has spread to the wires connected to them and will need to be replaced. This means opening up the unit and unsoldering the old wires between the contacts and the circuit board and replacing them with new ones.
You'll need to take great care as a flash capacitor can store a lethal charge, and you'll also need good soldering skills to both ensure that the new joints are sound and that you don't put too much heat into the circuit board causing damage.
The actual repair though just costs a couple of pieces of wire and a bit of solder, so is very cost effective if you have the tools and skills.
Sep 02, 2010 | Sigma EF-500 DG for TTL Flash
Atwood GCH10A-4E won't heat in electric mode. 12v power to circuit board no 12v power to relay. Is new circuit board only solution?
CHECK THE FUSES AND CIRCUIT BREAKERS IN THE CONVERTER BOX. MAKE SURE THE 110V SWITCH BEHIND THE WATER HEATER IS TURNED ON. IF THERE IS POWER AND "ALL" THE 110V SWITCHES ARE ON, TIME TO OHM OUT THE HEATING ELEMENT, LOCATED UNDER THE BOX BEHIND THE WATER HEATER.
IN ORDER TO HAVE 12V AT THE CIRCUIT BOARD, 112V POWER HAS TO GO THRU THE RELAY. SOUNDS LIKE U HAVE A WIRING PROBLEM SOMWHERE, EITHER AT THE SWITCH OR AT THE WATER HEATER SOMEWHERE.
Dec 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
A leaking coppertop battery has resulted in corrosion of spring terminal second from base. attemped cleaning of spring and New batteries will not power up the flash unit
If the corrosion worked its way in to the circuit board, you have 2 choices.
Get it repaired at Canon or somewhere else.
Buy a replacement.
Oct 20, 2009 | Canon Speedlite 550EX TTL Flash
I have a 92 S10 that does not get fuel. the fuel pump is working the injector relay seems to be working the injector gets power to one line on each injector and i can hear the injectors hum when i turn on...
YOUR PCM CIRCUIT BOARD THAT CONTROL THE INJECTORS IS NOT TRIGGERING THE INJECTORS.I WOULD SCAN IT FIRST BEFORE BUYING A NEW PCM.SCAN IT TO LOOK FOR PCM FAILURE CODE.
Sep 26, 2009 | 1992 Chevrolet S-10
Hitachi Plasma P50S601 no picture sound OK
probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Aug 30, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
Hitachi 55PD9700 sound no picture
upper y scan board had a blown chip. removed board and lower screen lit up. ordered a new upper y scan board.problem solved.
May 16, 2009 | Sylvania Televison & Video
Water under unit
I'm sorry to hear this.
If you're really lucky, and it was just wet while you were first testing it, it will have dried off since then and might work now. However, the odds are better that the problem is not a wet board, but rather a corroded board.
The water must have caused corrosion on the traces and/or components in the audio portion of the circuit board.
First unplugg the unit and all the cables. Use a good light to help you look inside the center of the audio jacks. Can you see any corrosion inside the jack? If yes, roll up a piece of emery cloth small enough to put inside and use it to clean the jack.
If that doesn't work, the unit would have to be taken apart. All the connectors removed. You MAY have to remove the VCR assembly if it is sitting over top of the circuit board. That's not fun.
The object is to remove the entire circuit board so you can put it on a bench or table. You'll need a good light and a magnifying glass.
You have to examine the entire circuit board for patches of rust. Pay particular attention to the bottom of the board as it was closest to the water.
Check the components for corroded leads,
check the ports where they are mounted to the board,
check the wiring harness connectors,
check the general condition of the board and the traces. Any traces that have rusted through will have to be repaired using jumper wire and solder. Rusted components will have to be reattached using solder, or replaced if they are unrepairable. Contaminated harness connectors will have to be resoldered at least, and may need jumper wire to repair traces they connect to. They may also require their pins to be cleaned, and the corrosponding harness may also need its matching connector cleaned. Check the harnesses for broken or rusted through wires and repair accordingly.
That's a lot of work, but it's unlikely you'll need to do all of it.
Once you find the rust, you can concentrate on that area and do a general check of the board after the repair.
If this isn't your cup of tea, time to buy a new one.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Apex Digital GB51HD09 51" Rear Projection Television Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
